Old 08-18-2014, 03:00 PM   #1
dfwplt
Default What IS this serial number?
I would really appreciate some help with this....
I can't tell if it starts with AA14... or AA4... or..???? then there's a 198...number below it...???
I'm new to this forum but I do have a Model A engine and VERY little Model A knowledge. Sure appreciate some help.
I found lists of S/N's and dates but don't know what number to use...
thanks very much.
Jim
dfwplt is offline   Reply With Quote
Old 08-18-2014, 03:19 PM   #2
rocket1
Default Re: What IS this serial number?
AA148,looks like it was restamped,maybe by a rebuilder.
rocket1 is offline   Reply With Quote
Old 08-18-2014, 03:26 PM   #3
Gumpy
Gumpy's Avatar
Im thinking the motor came out of a model A big truck, not sure about the numbers below, the truck could have been re-vined @ one time , do you have a title?
"I believe God is managing affairs and that He doesn't need any advice from me. With God in Charge, I believe everything will work out for the best in the end. So what is there to worry about". Quote by Henry Ford
Gumpy is offline   Reply With Quote
Old 08-18-2014, 03:27 PM   #4
Gumpy
Gumpy's Avatar
the number is star AA4846904 star
Old 08-18-2014, 03:32 PM   #5
Chris Haynes
Chris Haynes's Avatar
The face of the number boss is smooth. This tells you the original number has been removed. The font used in the numbers on it are NOT Ford font or size. Bottom line is that it is a serial number that has been altered.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 08-18-2014, 03:39 PM   #6
dfwplt
Thanks very much for the feedback. Very much appreciated.
I don't have a title. The engine was on a Pietenpol airplane. I don't suppose there's any other way to find out when it was built?
Old 08-18-2014, 03:58 PM   #7
Russ B
AA484690*. The 1 looks extraneous and stamped with a harder blow. The number below is a later stamping, with a smaller height font, IMHO.
Per Pluck's research/site the fonts are the earlier style, so that eliminates the * at the end from actually being a 4, as that would make the number too large/late for use of that font.
Russ B is offline   Reply With Quote
Old 08-18-2014, 05:01 PM   #8
Model A Man
Model A Man's Avatar
my guess is the motor was rebuilt July 14th 1987
Model A Man is offline   Reply With Quote
Old 08-18-2014, 05:31 PM   #9
peters180a/170b
peters180a/170b's Avatar
USE JB Weld on the numbers on the bottom and that extra 1 to fill them in and call it a day
peters180a/170b is offline   Reply With Quote
Old 08-18-2014, 05:31 PM   #10
Tom Wesenberg
Tom Wesenberg's Avatar
If you have a copy of the "Service Bulletins" you can look inside the lower engine to spot the differences and give the engine an approximate time period of build.
Old 08-18-2014, 05:54 PM   #11
Ron in Quincy
Ron in Quincy's Avatar
I believe the original engine number stamping is *AA4846904* ; this number equates to October 1928. The 6 and 9 are the early type numbers.
The other stampings are no doubt later and I would not even try to make a guess as to what they mean or when it was done ?
Ron
Ron in Quincy is offline   Reply With Quote
Old 08-18-2014, 06:02 PM   #12
dfwplt
Excellent, this is all very helpful. Thanks very much to all. Maybe June of 1987 is right!
My plan is to: Get out the JB Weld
and the grinder...hahahaha..
Ok, just kidding. thanks again to all. Very much appreciate!
JM
Old 08-18-2014, 11:16 PM   #13
redmodelt
redmodelt's Avatar
RE;Pietenpol airplane
The lower number could be an FAA number.
Old 08-19-2014, 08:15 AM   #14
Al Mack
Ron
One too many digits for an OCTOBER 1928 number. If you are saying the stamping has the following SEVEN DIGITS, 4846904, that would be a MARCH 1932 number. I don’t see any before or after the seven digit number. For comparison, take a look at my MARCH 1932 number AA4848750that is close to the last OEM number for any Model A and takes up the entire length of the number pad.
Al Mack is offline   Reply With Quote
Old 08-19-2014, 11:14 AM   #15
Chris Haynes
Notice how the numbers on the engine directly above are in line and straight. This is how numbers were stamped at Ford. They were held together in a mandrel and stamped all at once. Not the hap hazard crocked numbers on the engine in question. There is no doubt that it is a re stamp.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 08-19-2014, 11:21 AM   #16
Ron in Quincy
Al,
I screwed up when I typed the number, should have been: *AA484690* . I believe the last stamping is a *, not a 4 .
Ron
