10-11-2018, 01:06 PM | #1 |
new question-coil
Picked up the IH-200 capacitor today, NAPA didn't have a coil.
I've searched but didn't come up with a definitive answer, and on line search didn't help. I'm looking for a stock 6volt coil(no internal resistor) for a 48 f/head. I want one so I can send the one on it now to Skip. I also need shipping info for Skip. Thanks again for the help. Paul in CT. |
10-11-2018, 01:41 PM | #2 |
Re: new question-coil
You want a ~ 1.5 ohm coil for use without a ballast resistor on a 6v system or ~ 0.7 with a ballast resistor. If it is the stock setup with the ballast resistor under the dash, then the 0.7 ohm coil is what you need. You will most likely have a bit of a difficult time finding a 0.7 ohm 6v coil at a local parts house.
Here is my suggestion, temporally by-pass the original ballast resistor and run a 3.0 ohm coil. This site will give you all of the cross reference part numbers for a 3.0 coil. https://www.yoyopart.com/oem/1351760...n-ic9.html#top Last edited by JSeery; 10-12-2018 at 09:43 AM. |
10-11-2018, 01:56 PM | #3 |
flamingo,
go to www.fordcollector.com it will have all of skips information there. Super guy to deal with. |
10-11-2018, 05:12 PM | #4 |
I have a brown Ford logo coil that was rebuilt by Skip. Still in the box from Skip, never used as I just keep it for a spare. If interested, PM me.
10-12-2018, 06:12 AM | #5 |
Why not just wait to get your coil back from Skip? It will only be a week or so.
10-12-2018, 06:02 PM | #6 |
Thanks everyone. Going to be venturing out again Sunday to a show in Seymour, CT put on by the Lion's Club for many, many, many years. Paul in CT |
10-12-2018, 09:49 PM | #7 |
The 46 to 48 coils are what you want with the Ford mounting bracket. G.M.
www.fordcollector.com |
10-13-2018, 11:54 AM | #8 |
I had my coil rebuilt by Skip for my 47 truck 59 A B flathead.
