04-11-2019, 10:29 AM | #1 |
Repairing Castiron Sediment Bulbs
So you find that your Castiron Sediment Bulb has a small crack in it.
Did you repair it with success and just how did you do it or not? Did you use: Silver solder, Brass, JB Weld, Chuck it or other? Thanks. Pluck |
04-11-2019, 11:20 AM | #2 |
Re: Repairing Castiron Sediment Bulbs
Steve, I would look for a good replacement.
04-11-2019, 12:32 PM | #3 |
I first drill a small hole at the end of the crack to keep it from running any farther . I slightly V out the crack . I grind the metal around the crack for a better bond , I heat the area to be repaired, cherry red and use a brass rod to fill -repair the crack . I quickly put the sediment bowl in a box of sand and cover it up with sand to keep it from cooling too fast . This has worked well for me .
04-11-2019, 12:39 PM | #4 |
Steve, where is the crack? Is it in the outlet threads or elsewhere??
04-11-2019, 01:15 PM | #5 |
Hello Steve,
I made it like Bob. But I took a welding wire as a mix brass with silver with a lower melting point. Goes easy.
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
04-11-2019, 01:26 PM | #6 |
04-11-2019, 01:57 PM | #7 |
Since you have another one to use, that is fine however I can tell you from experience that good units that have good threads are getting hard to find.
As mentioned above, pin the end of the crack, grind a minor Vee in the crack, preheat, then use an Aluminum Bronze rod and TIG the crack. Cover with a heat blanket and allow to cool and you should be OK. Something else to consider is that we have found rusty sediment bulbs to be a source of problems in a carburetor. We now use gas tank sealer and coat the insides of the bulb during restoration. |
04-11-2019, 06:34 PM | #8 |
Thanks Brent...
Yes, I am even finding that soaking the bulbs in Evaporust does not really do an inside job justice! Pluck |
04-12-2019, 01:20 PM | #9 | |
Yes, my experiences are that Evaporust does not do well with crusty rust. We use stainless shot in a Rotoblaster to knock it all loose, but the problem is that once it is in bare metal, you then have the potential for rust to form again. If you need a specific product for the cast welding on something other than an exhaust manifold, look for a brand called Muggy Weld that can be TIG welded. |
04-12-2019, 01:44 PM | #10 |
We don't have much problem here in the Great Desert with water in the gasoline but I still remember the humidity problems from when I lived in Michigan, Rhode Island, NJ, Houston and Dallas.
And the Capitol of Humidity ... anywhere in Vietnam where "The Vietnamese National Bird" is a "B-52 Mosquito" that weighs more than 16 Oz and has a payload that exceeds a Huey UH1-B. I check the sediment bowls, gas tank, Carburetor bowls regularly for water just out of habit. |
04-12-2019, 02:17 PM | #11 | |
Pluck |
04-12-2019, 04:27 PM | #12 |
The problem with my cast iron sediment bowl is that the thread is very short - its only holding on by a couple of turns. Is it a design fault to have so few threads? It is otherwise in good condition.
