Old 07-15-2017, 02:51 PM   #1
Tod
Default New 8BA unforeseen delay.
I recently have had to make a procedural change in how I make my Model A blocks, so that change is going to take time away from completing the 8BA design. Since the change was already in my mind it won't delay things too long. I am very far along on the 8BA design but not quite ready to go to the core shop.
I am also in the process of moving out 2 CNC machines and bringing in a new one that has better capacity. It should be here the first week of August.
I will be trying to get 8BA blocks sampled asap.
Tod
Tod is offline   Reply With Quote
Old 07-15-2017, 02:54 PM   #2
19Fordy
19Fordy's Avatar
Default Re: New 8BA unforeseen delay.
Tod; You are amazing.
A man who puts his money where the gas pedal is.
Old 07-15-2017, 05:33 PM   #3
tubman
tubman's Avatar
I just looked at Tod's initial post about this; it was on May 5 of this year! I think we can cut him a little slack to while he improves his Model A block! All of this is less tha 3 months? When do you sleep, man?
Old 07-15-2017, 06:30 PM   #4
rotorwrench
rotorwrench's Avatar
The Motor City project is a good example of how long things can sometimes take and how far off the path with changes to the design it can get to.
It takes what it takes and it sounds like you're getting set up to a point that will get you there with better results.
Old 07-15-2017, 07:11 PM   #5
Tod
I have some process changes I need to make on the Model A block casting as cores for making a 5 main version are about to come in, as are cores for my new OHV head, and a dual plug Model A head. Pictured is the new machine that will replace 2 older ones. Plus, normal production needs to continue while I do everything else.
The newer Mazak FH680 has 80 tool magazine, CAT 50, availability for adding more pallets, larger memory than the other 2 machines combined, and is quicker. I didn't want to do this right now but I need to while I can get a good deal.
Tod
Old 07-15-2017, 07:19 PM   #6
tubman
tubman's Avatar
Tod, you are operating in a different universe than me!
Old 07-15-2017, 07:29 PM   #7
Tod
Nope. Nothing special here. Believe it.
Tod
Old 07-15-2017, 07:39 PM   #8
Bored&Stroked
Bored&Stroked's Avatar
Thats a good machine - especially for steel and cast iron . . . thanks for the update and I'm "on board" with this project - anything I can help with - just ask. Also, I will put a deposit down once we're closer to the "end game".
THANKS!
Dale
Old 07-15-2017, 07:40 PM   #9
tubman
tubman's Avatar
Whaddaya mean? My biggest acquisition in the last two years was a chop saw!
Old 07-16-2017, 07:31 AM   #10
corvette8n
corvette8n's Avatar
That's some awesome looking machine.
Old 07-16-2017, 08:04 AM   #11
Ol' Ron
Ol' Ron's Avatar
You mentioned dual plug heads. I think the location of the spark plug in a flathead would best be served by placing it in the center of the transfer area and at the same angle. When flow benching The flathead I made up several combustion chambers to observe the affect of the transfer area on flow. The best flow was in the 10 to 12 degrees similar to the stock EAB head. However this reduced the CR and was only effective in the upper RPM range. Reducing this to 8 degrees provided a higher CR with affecting the flow that much. Also the exit of the transfer area must be taken into consideration. If the plug were installed in the center and at an 8 degree angle, a power tip plug could be used and much better fuel economy could be had.
Old 07-16-2017, 08:54 AM   #12
Tod
The dual plug heads are for the Model A. Snyder needs 20 of them for airplane guys. I will also offer them in iron for street guys.
Tod
Old 07-16-2017, 09:09 AM   #13
estout81
estout81's Avatar
Here's Mark Kirby's Motor City engine.
estout81 is offline   Reply With Quote
Old 07-16-2017, 12:19 PM   #14
Tod
Totally irrelevant.
Tod
Old 07-16-2017, 12:40 PM   #15
rotorwrench
There must be some model A Pietenpol fans out there. He started out using Model T or Ace 16-valve engines but the Model A had a lot more power with not much change in weight. He did have to design it with a long tail on them though to keep the weight & balance within range. They could run a dual mag on there but they might have some other form of dual ignition. It's mostly for reliability since it only gives a flathead slightly better performance.
That Motor City engine may end up being a one off. They don't seem too interested in doing anything but showing it to folks at shows & swap meets.
Old 07-16-2017, 12:53 PM   #16
hardtimes
hardtimes's Avatar
Originally Posted by Tod View Post
Totally irrelevant.
Tod
Hey Tod,
Thanks for the update !
That Mazak is awesome !! Heck , it's a big as my house or as a small bowling alley, eh !!
Doctor says...Don't burn candle at both ends, and DON'T lift any blocks .
Stay safe/healthy my friend.
hardtimes is offline   Reply With Quote
Old 07-22-2017, 07:31 AM   #17
Tod
Originally Posted by hardtimes View Post
Hey Tod,
Things are getting back on track. I finalized the foundry equipment purchase yesterday and the new CNC will be at the shop in a week or 2.
Additional tooling is in place for machining Model A blocks and the new machine will allow me to machine 8BA blocks at the same time. The model is coming along again.
Tod
Old 07-22-2017, 09:09 AM   #18
tubman
tubman's Avatar
Totally irrelevant.
Tod
That's what I was thinking as well. Totally out of place.
Old 07-22-2017, 10:17 AM   #19
estout81
estout81's Avatar
Sorry! Guess I should go back to reading and not posting!
Old 07-22-2017, 11:25 AM   #20
prpmmp
Your just trying to be part of this forum!no big deal!Keep reading and posting thats what this forum is for!! Pete
prpmmp is offline   Reply With Quote
Thread Tools
Display Modes
