Old 08-08-2010, 07:48 AM   #1
01aford
01aford's Avatar
Default Cleaning White Walls
My new Cooker white walls have some grease fingerprint stains. I don't want to use an SOS pad. What do you use one your white walls to clean them up?
01aford is offline   Reply With Quote
Old 08-08-2010, 07:54 AM   #2
Henry/Kokomo
Henry/Kokomo's Avatar
Default Re: Cleaning White Walls
Westley's "Bleche-Wite" Wierd spelling, but the stuff works well.
Henry/Kokomo is offline   Reply With Quote
Old 08-08-2010, 08:00 AM   #3
Pat/Ohio
Pat/Ohio's Avatar
I agree with Henry. Wesley's does a terrific job on whitewalls. By the way, I also use Wesley's white wall cleaner on to remove mildew and bug stains from vinyl siding on the house...works great ! Pat
Pat/Ohio is offline   Reply With Quote
Old 08-08-2010, 08:05 AM   #4
37 Coupe
37 Coupe's Avatar
Mr.Clean Eraser works good also for grease or stain spots along with Westleys.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 08-08-2010, 08:35 AM   #5
Marv
Marv's Avatar
You can buy Westleys at a Dollar store. Marv
Marv is offline   Reply With Quote
Old 08-08-2010, 09:40 AM   #6
denverslim
denverslim's Avatar
Just use a little dish soap and warm water. For the harder stuff like greasy fingerprints, I use a little Arm and Hammer baking soda. Just put a little on a sponge and rub it...slim
denverslim is offline   Reply With Quote
Old 08-08-2010, 09:44 AM   #7
Pete Fl/Wi
Pete Fl/Wi's Avatar
For hard to get out stain hit it with brake cleaner and quick wipe with a rag. Pete
Pete Fl/Wi is offline   Reply With Quote
Old 08-08-2010, 11:09 AM   #8
hombres ruin
hombres ruin's Avatar
Coker makes a great whitewall cleaner with no bleach.Remember westleys has bleach and its the bleach that dries out the rubber and causes cracks.Bleach is not good for tires.The coker product works better than the westlys and it saves your tires.
"I have built my organisation on fear"..Al Capone.
hombres ruin is offline   Reply With Quote
Old 08-08-2010, 04:09 PM   #9
jdl
jdl's Avatar
Send a message via ICQ to jdl
Diamond Back Tire co. says not to use any cleaners with bleach, they recomend super clean, purple jug. it works very good. heres a link on how to clean their whitewalls...
http://www.widewhitewalltires.com/cleaningtips.html
jdl is offline   Reply With Quote
Old 08-08-2010, 05:08 PM   #10
Steves46
Steves46's Avatar
Simple Green has worked for me.
If it aint broke, don't fix it!
Steves46 is offline   Reply With Quote
Old 08-08-2010, 05:42 PM   #11
hombres ruin
yep thats right coker recommend the same thing.Bleach sucks the moisture out of rubber causing cracks
Old 08-08-2010, 07:26 PM   #12
345 DeSoto
345 DeSoto's Avatar
Location: Skaneateles,NY(summer)/Port St.Lucie,FL(winter
Westleys does not contain bleach. It's main cleaning ingredient is Sodium Metasilicate, the same as Castrol Super Clean. I used Westleys until I compared labels with Super Clean...Super Clean being cheaper than Westleys, that's what I use now...
..."If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit"...
345 DeSoto is offline   Reply With Quote
Old 08-08-2010, 09:15 PM   #13
Mr.34
Mr.34's Avatar
I use to use Westleys until the guys at the EF V8 Nationals convinced me to use about anything but Westleys. It is full of bleach and a good tire company will attest to this. Do not use bleach as it will take the dirt off and some of the rubber little by little too. Not so quick to condemn SOS pads. Thats what I used as a kid and now went back to it for the perfect job. For quick clean ups, Simple Green or other less harsh cleaners will do the job.
Mr.34 is offline   Reply With Quote
Old 08-08-2010, 09:22 PM   #14
Mr.34
Mr.34's Avatar
I will look at the Westleys I have in the shop. I may be wrong about it having bleach. If you doubt it has something VERY harsh in it, take a dark rag and use some Westleys. When I saw all the white on the black wash cloth I knew I was doing harm. You can feel the rubber gummy where you use it. Like all topics on here, everyone has opinions. Too many serious car guys have warned me about Westleys so I stopped using it.
Old 08-08-2010, 10:03 PM   #15
hbleadsled
i HAVE NEVER USED WESTLEAS i HAVE USED SOS PADS FOR 50 YEARS AND SOME TIMES SIMPLE GREEN ON SPOTS i WOULD NOT USE ANY HARSH CLEANERS WITCH WOULD HARM YOUR WHITE WALLS .HAROLD, CENTRAL COAST CA.
hbleadsled is offline   Reply With Quote
Old 08-09-2010, 09:23 AM   #16
36tbird
why are you hollering at us?!
36tbird is offline   Reply With Quote
Old 08-09-2010, 10:02 AM   #17
britman
check out http://diamondbacktires.com/ruins_whitewalls.html
bd
britman is offline   Reply With Quote
Old 08-09-2010, 11:58 AM   #18
RJD
Oven cleaner, I've been using it for over 20 years
RJD is offline   Reply With Quote
Old 08-10-2010, 09:08 AM   #19
Lyndon
Lyndon's Avatar
Try the mild cleaners first. Just prior to taking my Model T to a show, I bought some tire cleaner at the parts store that ended up doing a number on the painted parts of the first wheel I tried it on. The instructions should have said to remove the tire from the rim before application, rather than just saying to be careful about getting it on any painted parts.
Lyndon is offline   Reply With Quote
Thread Tools
Display Modes
