11-29-2019, 09:28 PM | #1 |
Isky Max 1 valve lash
Does anyone have a recommendation for cold valve lash on a Isky Max 1 cam. Isky recommends .014 hot. It's obvious they must not be familiar with flatheads. I know that generally on an ohv engine you give about +.002 for a cold setting. Motor has close to 800 miles so everything should be settled in by now. This is a 59AB Any info. is appreciated.
11-30-2019, 06:52 AM | #2 |
Re: Isky Max 1 valve lash
The lash is 0.014" cold for this cam. there was a thread here recently where someone contacted Isky for confirmation. Hot lash for a Flathead is silly!
Here is the link: https://www.fordbarn.com/forum/showp...22&postcount=7 Glenn Last edited by glennpm; 11-30-2019 at 06:57 AM. |
11-30-2019, 08:36 AM | #3 |
