01-29-2014, 10:29 AM | #1 |
In need of a measurement
I searched every where but no definite dimension.... I have a 1930 Tudor, I need the front dimension from outside post to outside post at the top of front of car. I cut and replaced the the front header shelf and want to make sure the figment is okay before welding. Thank you...
01-29-2014, 12:04 PM | #2 |
Re: In need of a measurement
Thank you very much, I missed by 1/2 an inch, now I can get on with my project.
01-29-2014, 12:08 PM | #3 |
maybe you should put the window in ,that should tell you . are the doors on
01-29-2014, 12:17 PM | #4 |
Yes the doors are on, the windshield hinge is very tight between the pillars, if I can spread the pillars another 1/4 inch or I trim the outside edges of hinge which I would not rather do. This car was hit hard in the past and was repaired half ass, seems a lot of bad bends in front body section.....
01-29-2014, 12:31 PM | #5 |
