Old 09-15-2021, 05:23 PM   #1
52flthed
Default Vintage battery kill switch?
What does a period correct one look like if there was ever such a thing? Any pictures, sources or advice on their use ; pros and cons?
52flthed is offline   Reply With Quote
Old 09-15-2021, 09:28 PM   #2
slowforty
slowforty's Avatar
Default Re: Vintage battery kill switch?
I used a copper lever switch. It works a lot better than the green wheel switch. No parts to melt if you crank your starter too long. Available on E-Bay or amazon. check for best price
slowforty is offline   Reply With Quote
Old 09-15-2021, 09:39 PM   #3
corvette8n
corvette8n's Avatar
I found a nos Cole Hersee switch made in Boston for my 41 Ford.
File Type: jpg 5738A885-44DE-4AB4-907A-A92F9BA8FE55.jpg (27.0 KB, 433 views)
Old 09-15-2021, 09:46 PM   #4
petehoovie
petehoovie's Avatar
Old 09-15-2021, 11:07 PM   #5
51 MERC-CT
51 MERC-CT's Avatar
This is my period correct battery disconnect.
Old 09-16-2021, 07:31 AM   #6
russcc
Cole-Hersee has always been the gold standard, and there old made in USA ones out there if you are looking for patina. New ones are made in Mexico.
Old 09-16-2021, 07:45 AM   #7
big job
big job's Avatar
Whats so vintage about a kill switch? go any where and get one. This switch doesn't care about voltage all my machines have those from Napa...
big job is offline   Reply With Quote
Old 09-16-2021, 07:32 PM   #8
52flthed
Thanks for the responses so far.. The knife switch seems to most promising so far. The C.H. switch is attractive but I believe those have to be mounted? I prefer something local to the battery. Yes the green knob kind Ive had problems with years ago and Ive read a lot of negative things about them. A wrench is not a good idea as it would wear out the soft battery post and terminal and cause connection problems. If anyone has any pictures of their knife switch or Cole H. Switch I would love to see how you've mounted them. Thanks.
Old 09-16-2021, 07:38 PM   #9
paul2748
paul2748's Avatar
Always used a 1/2 wrench as my battery disconnect. Never heard of wearing out the battery post ??????. Been doing it for years, never wore out a battery post or the clamp.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 09-16-2021, 08:00 PM   #10
51504bat
51504bat's Avatar
If you want a terminal mount switch you might try to find one from an English car. They used to be repopped but its been a long time since I messed with English cars. If you do decide to go this route and you do find one it will be pricey. But they are pretty fool proof. Unlike the green knob ones that mount on a terminal post.
Old 09-16-2021, 08:03 PM   #11
34PKUP
34PKUP's Avatar
A wrench is not a good idea as it would wear out the soft battery post and terminal and cause connection problems..
In the decades that I have been using a wrench to disconnect batteries as required, I have not seen any wear to the post or anything else.
34PKUP is offline   Reply With Quote
Old 09-16-2021, 08:50 PM   #12
Lawson Cox
Lawson Cox's Avatar
I'll drink to that.
Old 09-16-2021, 08:51 PM   #13
52flthed
Thanks for the suggestion! I will look into it.
Old 09-16-2021, 09:06 PM   #14
52flthed
Im using a wrench now to disconnect the battery during periods of storage. Its NG.. I want the safety and convenience of a switch. And a switch that will look like it belongs in my truck. Thats why I posted this question.
I can already see wear on the post and terminal. This observation and eventual problem Ive read about on other forums which leads me to that conclusion. Sorry but no wrench for me.
Old 09-16-2021, 11:32 PM   #15
cas3
Personally, I turn my car off in the fall, and I start it up again in the spring. Many folks in the hobby like the disconnect switches, and many tell of the failures of the new modern junk they sell us. Those old CH switches have been around for about 75 years in every school bus and big trucks, if its an old still made in USA switch I'd say thats as good as it gets. If you want something cool, like on the dash of an old speedster, I would go with a Knife switch
Old 09-17-2021, 03:06 AM   #16
Crankster
Crankster's Avatar
The cheap generic import battery replacement cable terminals will deform badly very quickly, the good stuff is always plated solid copper crimped terminals and don't suffer from this problem.
Disconnecting the battery (one way or another) is a good practice in the off season especially, what with vintage wiring, and also the possibility of rodents or vermin chewing on wiring. More than one car fire has started this way.
Crankster is offline   Reply With Quote
Old 09-17-2021, 10:07 AM   #17
52flthed
Yes I agree about the CH switches but I think they're mounted in a remote location away from the battery is that right? I was looking for something that switches near the battery. I had a little fire with an engine compartment light last year. Since then Ive had the whole truck re-wired as there were other symptoms of bad grounds and such with the lights. So being extra cautious here and thinking about disconnecting the battery as built in feature doesn't sound like a bad idea. Thanks for the ideas so far.
Old 09-17-2021, 11:27 AM   #18
Bob C
I think you are overthinking this. Just make a bracket to mount the switch on the
inner fender panel near the battery. Run a short cable from the battery to the switch
and another from the switch to where ever the original cable was bolted to ground.
Old 09-17-2021, 11:53 AM   #19
rotorwrench
rotorwrench's Avatar
Put a fuse kit for the starter switch buss connection terminal on there and pull the fuse out to disconnect. It may not be original but the fuse will certainly protect the cars wiring from eventual short circuits. A person could also wire it for an aircraft type resetable push pull type circuit breaker of the correct system amperage rating. This would make it easier to pull the breaker button and open the circuit for longer storage. A person would have to get creative to mount and protect it but it could be done pretty easy.
The fuse kit is less expensive than the circuit breaker for sure but either one is less expensive than a burned up car or even a burned up garage where the car may be stored.
I keep thinking I'm on the Model A Forum! Later cars already have either fuses or circuit breakers but a CDM type Klixon breaker might work as a shut off if close to the solenoid connection to the battery.
Old 09-17-2021, 02:49 PM   #20
deuce lover
deuce lover's Avatar
Here's a vintage one ,WWII variety.Fit it to the steering column.
https://www.ebay.com/itm/39357761115...MAAOSwTpdhQ-AI
And another true vintage:
https://www.ebay.com/itm/22368123342...AAAOSwaIpb44uW
