12-30-2013, 10:22 AM | #1 |
32 boat tail horn.
I need help on wiring a boat tail horn to my coupe. Does anyone in barners land have a diagram on this thanks- G- man
12-30-2013, 11:04 AM | #2 |
Re: 32 boat tail horn.
It would be helpful to know if your coupe is a four or a V-8 and if a four, an early car without a fuse block or a late car with a fuse block and foot-controlled starter switch. Also are yoiu using original type wiring with a light switch mounted on the bottom of the steering column.
12-30-2013, 11:15 AM | #3 |
It's a v8 and using original wiring with horn button on steering wheel and light switch mounted on bottom of steering column . Thanks
12-30-2013, 02:16 PM | #4 |
The attached copy of an original wiring should be helpful.
12-30-2013, 10:36 PM | #5 |
Are you running all your own wiring? My Uncle's solution was to wire it to a doorbell button on the dash (above the vacuum gauge)….
Short URL: http://smu.gs/14g7eDW |
12-30-2013, 10:48 PM | #6 |
