Old 08-18-2019, 12:29 PM   #1
russcc
Default E Brake cable lube
I have the original E brake cable out of the '40. It works fine, but I would like to lubricate it while it's hanging up vertical. Any suggestions on a lube. How about Wurth HH-SK, or ? Thank you Fordbarners.
Old 08-18-2019, 02:09 PM   #2
supereal
supereal's Avatar
Default Re: E Brake cable lube
Use lithium "white grease", available at most parts stores.
supereal is offline   Reply With Quote
Old 08-18-2019, 03:08 PM   #3
1931 flamingo
1931 flamingo's Avatar
The white grease hardens after a while. JMO
Paul in CT
Old 08-18-2019, 03:33 PM   #4
Kube
Kube's Avatar
I lubricate mine while it is hanging - prior to installation. I use a CRC product similar to Liquid Wrench. It flows in to the outer cable housing and allows some reasonable confidence that it got inside where it is (in my opinion) most required.
Old 08-18-2019, 03:33 PM   #5
Kube
Kube's Avatar
Paul in CT
It does, but even then won't allow the formation of rust beneath it.
