Old 07-03-2020, 04:10 PM   #1
Wayne Schuenke
Default starter drive
Can I replace the small spring that hold the starter gear away flywheel or should I just replace the whole starter drive my 1950 226 ci ford
Wayne Schuenke is offline   Reply With Quote
Old 07-03-2020, 08:10 PM   #2
FortyNiner
FortyNiner's Avatar
Default Re: starter drive
I would have the starter rebuilt.
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 07-04-2020, 05:27 AM   #3
koates
Those pinion return springs are very soft. Watts wrong with yours? All the thirties drives did not have that return spring and they worked fine. Make sure the spiral area is free from crud or rust so that the pinion works back and forth freely. I very lightly give it a squirt with pressure pack oil. Not WD 40. Regards, Kevin.
koates is offline   Reply With Quote
Old 07-04-2020, 08:59 AM   #4
Wayne Schuenke
the spring got stuck in the gear and locked the starter up pulled the spring out and it seam to go back and forth ok
Old 07-04-2020, 09:12 AM   #5
joe 1950
joe 1950's Avatar
I had that same problem with my 1950 cpe v8 it was a problem that they had back then sometimes you could rock it back and forth in gear of course the key must be off and it would unlock itself but i still replaced it with a new nos their out there I got mine from South side obsolete out of minn he has a small website hope this helps
joe 1950 is offline   Reply With Quote
Old 07-04-2020, 09:19 AM   #6
Wayne Schuenke
I think I will replace and keep this one for a spare thanks
