Old 04-12-2016, 06:31 PM   #21
Del in NE Ohio
Del in NE Ohio's Avatar
Default Re: Locked-up rear end
That's my plan. I'm hoping for a u-joint fatality.
Del in NE Ohio is offline   Reply With Quote
Old 04-12-2016, 07:18 PM   #22
Tom Wesenberg
Tom Wesenberg's Avatar
If you don't find any problem at the clamshell, then you can remove the right brake drum and left side axle tube bolts, and pull the axle assembly out the left side.
Old 04-12-2016, 09:25 PM   #23
larrys40
I agree with Tom but I think it's almost best to undo the clamshell and pull the rear axle back a little . you can then use a pair of channel lock pliers to tey and turn the driveshaft, you can complete removing the rear axle further back to access the left side housing easier to remove and also check out the u-joint and driveshaft. It's possible you have a pinion bearing issue , u torque tube/houaings and hopefully not a gear issue. Your spiders and axles appear to be ok as you turned them both in opposing directions ok .
Let us know. Best of luck!!
Larry Shepard
larrys40 is offline   Reply With Quote
Old 04-12-2016, 11:13 PM   #24
Bob from Northport
Bob from Northport's Avatar
We had the very same thing happen in my shop last summer. One of the driveshaft bearings had disintegrated, and the small rollers were locking up the ring gear. I'll bet that is what you will find when the rear is disassembled. Car was driving down the roadway, and suddenly just locked up.
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 04-13-2016, 05:41 AM   #25
Del in NE Ohio
My efforts will now have to wait until Saturday. Delayed by good weather!
Old 04-13-2016, 11:42 AM   #26
Tom from Drippin'
Tom from Drippin''s Avatar
I had a problem with the same symptom in a '30 CCPU I once owned. The bearing in the torque tube (near the U joint) came apart and the rollers jammed between the drive shaft and the inside of the torque tube.
Transmission would shift, but letting the clutch out would stall the engine. The rear wheels were locked up.
Remove the rear end and check torque tube before cracking open the differential.
The pursuit of excellence is healthy and rewarding.
The pursuit of perfection is frustrating, neurotic and a terrible waste of time.
Tom from Drippin' is offline   Reply With Quote
Old 04-19-2016, 05:03 PM   #27
Del in NE Ohio
UPDATE! Returned today to lower/roll out rear end assembly. We found catastrophic failure of universal joint. Easy fix, back on the road this afternoon. Check out the photos.
Thanks for all of the responses!
Old 04-19-2016, 05:07 PM   #28
Tom Wesenberg
You sure did luck out.
Is this what happens when you don't pack the cavity full of Mystik JT-6 High Temp grease?
Old 04-19-2016, 05:09 PM   #29
Big hammer
Wow you got to quit dumping the clutch when your leaving tree at the drag strip !! :-)
Old 04-19-2016, 05:30 PM   #30
Mitch//pa
Thanks for the update ... That's good news
Thread Tools
Display Modes
