03-17-2017, 10:08 PM | #1 |
Eaton radiator cap
Hi, who are the experts on the Eaton two piece radiator caps?
I purchased an original cap today at a swap meet but the top is damaged. Does removing the centre rivet allow the locking centre to be removed from the shell or do you guys have a better way of repairing the stainless steel top. The knurling and base are good. Thanks Richard |
03-17-2017, 10:15 PM | #2 |
Re: Eaton radiator cap
MARC had an article in their magazine a while back. I don't know the issue.
Here it is; “Stainless Steel Cap Dent Removal”: Model A News /56/2/17 (2009)
What's right about America is that although we have a mess of problems, we have great capacity - intellect and resources - to do some thing about them. - Henry Ford II Last edited by Mike V. Florida; 03-17-2017 at 10:30 PM. |
03-18-2017, 03:48 AM | #3 |
eaton caps
the answer is no the rivet only holds the inner parts together. you need to peel the upper part of the cap off,
03-18-2017, 05:13 AM | #4 |
I've been told it's been done by heating the edge with a torch and pulling with pliers to separate the halves works. I've also been told soldering "dent pullers" (wire or metal rods) works. I have yet to try either. The article mentioned above involves slicing the interior half at the edge to release the pressure and pulling apart wth pliers.
03-22-2017, 07:19 PM | #5 |
