03-27-2016, 10:34 PM | #1 |
Weight Tolerances on Rebuild
I'm ready to put my engine back together. All pistons, rings and valves, guides & springs are new, all that stuff weighs the same for each cylinder. I am reusing the babbitt rods, since all babbitt looks great, and within specs.The trouble is, the rods are not all the same weight. How far can they vary in weight before it causes more vibration than acceptable? I am including a chart of the before and after weights of parts (somebody threw together some mismatched parts).
Bottom line, since the babbitt is good, I'm trying to save a shipload of money from buying rebabbitted rods that may weigh different as well. the rods and caps weigh respectively: 1. 734 g 2. 748 g 3. 740 g 4. 718 g (All other parts are matched weights) -Chuck
... prosperity is not the product of charity but of industry - HENRY FORD |
03-27-2016, 10:35 PM | #2 |
Re: Weight Tolerances on Rebuild
Sorry, I tried to upload a spreadsheet of all the weights, but it is an "invalid file". Oh well...
03-28-2016, 12:00 AM | #3 |
I'm sure others will "weigh" in on this but I think those rods are too far off to give a smooth running motor. I believe that + or - one gram is closer to what you need. If you try to match the weights yourself be careful where and how you grind.
03-28-2016, 12:05 AM | #4 |
You also need to weigh big end and small ends of the rods and have them weigh the same.
Not just the total weight of the rod. |
03-28-2016, 12:08 AM | #5 | |
Welding may warp them though. Should I drill some holes through the middle, spacing them?
03-28-2016, 12:16 AM | #6 |
Herm. |
03-28-2016, 12:21 AM | #7 | |
I could also talk to Bert's and see if Steve has just two to sell me that may be better matches.
03-28-2016, 12:25 AM | #8 |
I think an exchange on a set of babbitt rods is only about $60 or so. They need to tell me the weights before I get them though. It can't be more mismatched than what I have now.
03-28-2016, 07:10 AM | #9 |
I'll probably get a shipload of flack for this, but here goes; Why can't you drill a small hole in each of the heaviest rods to equalize the weights? There are 28 grams to the ounce and you're only 16 grams apart, or slightly more than a half an ounce. I don't know how big a hole that it would need to make up this weight, but is this solution feasible?
Terry |
03-28-2016, 08:20 AM | #10 |
Trust Herm on this one. #2 at 748 grams and #4 at 718 grams. That a 30 gram difference.You will never be able to grind that much weight off one rod without weakening it. And welding on the shank of a rod is a no-no also. It would well be worth the the expense of the new rods since you already have all the other internal new. Dont take the risk.
Had to replace an engine in a friends car several years ago when a rod broke and threw it through the side of the engine. Guess what. The rods had been welded to balance them. One broke at the weld and one more was cracked. |
03-28-2016, 08:54 AM | #11 |
With all that work and expense why cheap out now? Replace with new and do a proper job or you will likely regret your decision at a later date. Wayne
03-28-2016, 08:56 AM | #12 |
From the factory...
The rods were built to a certain weight at each end +-1 gram. When assembled the piston, pin and rod assembly was weighed and put in one of 4 bins. Any 4 taken from a bin would be within 4 grams total weight. Crank was done to 1/4 ounce of balance and the flywheel was mounted to less then .001" from the centerline. You really need the balance to be very tight to get minimal vibrations. Significant out of balance on the crank end will limit you top end and increase the vibrations affecting the life of the babbitt. You have to build the A engine like it is a race car engine if you want it to be like a new factory car. |
03-28-2016, 09:40 AM | #13 | |
03-28-2016, 12:15 PM | #14 | |
OOOPZ! My Bad!I see that there are 30 grams difference between the heaviest and the lightest, not 16 as I said. This changes things drastically. Don't know how I missed that!
Terry Quote:
03-28-2016, 01:30 PM | #15 | |
I'll be calling Bert's within minutes for rod exchange.
03-28-2016, 01:33 PM | #16 | |
Yes Terry, If they were under 10 grams apart, I would have done some grinding, but ALAS, it is far worse! Thanks to all for responding. I will post my findings from Bert's this evening.
03-28-2016, 02:06 PM | #17 |
BE safe, go ahead and drop by and talk to our buddy john cosper. Tell him what you've run into and I bet he'll help you out. Tell him tony white in Lafayette, LA said hi. Have fun modelAtony tony white Lafayette LA
03-29-2016, 12:06 AM | #18 |
We don't have enough information to say those rods can not be balanced. I have balanced rods that were FAR worse than that.
We need the big and small end weights seperately. Worst case, if all of the unbalance was on the big ends, (not likely) the lightest ones can be brought up in weight easily. To check them properly, you will need a setup similar to the picture. NO WELDING or HOLE DRILLING!!!! |
03-29-2016, 09:04 AM | #19 | |
Fearless |
03-29-2016, 09:20 AM | #20 |
that is how he wants it to look
five-oh-five- eight-three-six- three-one-one-oh
'31 180A |
