08-28-2021, 12:52 PM | #1 |
Anyone using an air/fuel meter?
There are two air/fuel meters that I know of that can be bought from about $80 to $160 on Amazon. The meters will give you a reading of whether your car is running rich or lean or just right while you are driving. Some welding is required. These gauges will tell you if your GAV is set right or if there is a clogged jet in the carburetor.
Is anyone running one?
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 08-28-2021 at 12:57 PM. |
08-28-2021, 03:43 PM | #2 |
Re: Anyone using an air/fuel meter?
Not one of those ,but I use an innovate one to set up the mixture on both my A and v8s.
Lawrie |
08-28-2021, 03:49 PM | #3 |
I might get one for my Turbo Eclipse when I turn the boost up to 16 psi and need to make sure it's not running too lean, but for the Model A? Don't think so.
08-28-2021, 04:50 PM | #4 |
Been using tail pipe probes in diagnostic machines [ Sun] for 6 decades. They work well. But, I'm not going into stuff like this very far anymore.
08-30-2021, 09:10 AM | #5 |
I used an Innovate unit to set up my weber carb. After a couple of months my sensor would crap out. In the mean time it worked great.
1965 Lotus Elan S2 1930 Model A Sport Coupe |
08-30-2021, 09:33 AM | #6 |
I suspect that many of the cars would run rich enough that the sensor would get contanimated quickly from being too rich |
08-30-2021, 09:44 AM | #7 |
IThe last time I stuck a probe in the A tailpipe was in the OBD1 days and it would pass. So that was what 1996 I think.
08-30-2021, 10:22 AM | #8 |
I use an exhaust temp ga. in my Bonneville engine, it and plug readings tell me what I need to know.
08-30-2021, 10:57 AM | #9 |
Had a smog test jsut for fun. The probe measured an air fuel mixture to 22/1. The guy told me I had to richen the mixture. I told him the gauge was wrong, the car would even not run with 22/1. Kinda funny
08-30-2021, 11:49 AM | #10 |
08-31-2021, 03:17 PM | #11 |
Yep
08-31-2021, 06:16 PM | #12 |
Malak, nice.
PC/SR, There must have been some oxygen getting into the exhaust somehow.
08-31-2021, 06:51 PM | #13 |
09-01-2021, 03:41 PM | #14 |
I would love to put one in my 30 CCPU if I could find a way to get it to work on a 6V positive ground system.
AL in NY |
09-01-2021, 08:12 PM | #15 |
Al, Google 6 volt to 12 volt converter.
09-02-2021, 03:59 PM | #16 |
