Old 03-20-2018, 05:30 PM   #1
30aadoodlebug
30aadoodlebug's Avatar
Default Removing timing gear nut
I have the socket wrench attachment, but this sucker won't budge. Thoughts?
30aadoodlebug is offline   Reply With Quote
Old 03-20-2018, 05:48 PM   #2
700rpm
700rpm's Avatar
Default Re: Removing timing gear nut
Put a long pipe over your wrench handle for more torque. Put in first or reverse gear. Set your parking brake. Stuff a large heavy rag, like an old bath towel, between the gear and the pan to help keep it from turning.
Ray Horton, Portland, OR
Old 03-20-2018, 06:14 PM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
WHACK it with a chisel & a BIG HAMMER, it's easy!
Bill Bang
"THE ASSISTANT GURU OF STUFF"
Old 03-20-2018, 06:59 PM   #4
Dick M
Dick M's Avatar
Send a message via Yahoo to Dick M
It is not advised to stuff a rag in the crank gear. Much better to clamp the timing gear. Use 2 slats of wood about 4 inches long and 2 "C" clamps. Clamp the timing gear by placing one slat on the back side of the timing gear and one slat on the front side of the timing gear. Then tighten the "C" clamps on both sides of the timing gear. The slats will use the pan as a stop. You can also use this method to torque your new timing gear.
You can use a cheater on you ratchet. However, I have found the best way to get a stubborn cam nut loose is to use an pneumatic impact gun.
Dick M is offline   Reply With Quote
Old 03-20-2018, 07:38 PM   #5
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Use a portable air compressor with a air ratchet. On and off easy, with no damage.
Or a hammer drill.
Old 03-20-2018, 08:22 PM   #6
700rpm
700rpm's Avatar
You’re probably right about the rag. The clamps sound like a good way to go. Some of us old guys who have been doing this for 50+ years have trouble adapting to newer methods.
Old 03-20-2018, 08:59 PM   #7
30aadoodlebug
Ok guys, Thanks.
I gave up around 7:00, as it started to get freezing out! I put a pair of vise-grips on the old timing gear to act as a stop on the frame which worked very well. The issue Im finding is that it the nut seems to be pretty well rusted on there. I soaked it in penetrating oil, and I'll attack it with the flaming tomahawk tomorrow night after work.
Old 03-21-2018, 09:33 AM   #8
katy
katy's Avatar
Bill Bang
Ditto
katy is online now   Reply With Quote
Old 03-21-2018, 10:51 AM   #9
harryc
That's the way it always used to be done. Have done it myself many times
harryc is offline   Reply With Quote
Old 03-21-2018, 11:30 AM   #10
WHN
Bill Bang
I have seen a lot of timing gear nuts that look like they have been removed this way.
Old 03-21-2018, 11:33 AM   #11
SeaSlugs
SeaSlugs's Avatar
Originally Posted by 30aadoodlebug View Post
Ok guys, Thanks.
lol flaming tomahawk - never heard it called that.
Yea let it soak overnight and see what the morning brings before getting torches involved.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 03-21-2018, 12:51 PM   #12
28
Impact gun or impact wrench. Or bang on it like a monkey like bill suggested.
Getting a bigger lever is the best sure fire way to end up with a broken bolt when something won’t budge. Impact guns are a game changer.
28 is offline   Reply With Quote
Old 03-21-2018, 01:06 PM   #13
hardtimes
hardtimes's Avatar
Thoughts...yes.
Is this an old rusted engine block ? If so, yeah rust is to be expected. If not old rusted block, remember that that area is lubed regularly and should not be rusted on. Also, that nut is supposedly put on with no less than 100 ft lbs torque !
The 'gear guru' McEachern, says NEVER put rags and that type stuff between gears, as you will ruin something !
So, if rusted soak then big impact wrench.
If not rusted impact wrench is your friend.
Old 03-21-2018, 01:08 PM   #14
john in illinois
john in illinois's Avatar
I always use a 1/2' impact and replace the bolt with a new style hex cam bolt.
John
john in illinois is offline   Reply With Quote
Old 03-21-2018, 01:13 PM   #15
John
John's Avatar
On a very stubborn nut I had, I drilled a couple of holes in the nut and split it with a chisel. It then came off easily.
John is offline   Reply With Quote
Old 03-21-2018, 06:13 PM   #16
Big hammer
Bill Bang
When I work on my A, I always use a BIG HAMMER :-) Thanks Bill !
get a bigger hammer tap done
Old 03-21-2018, 07:41 PM   #17
30aadoodlebug
Yeah, that's a term us whippersnappers use in the v8 world!
I soaked the hell out of it again before work, and when I got home it still wouldn't budge. Time for the old flaming tomahawk!
