12-10-2018, 11:35 PM | #1 |
Proper coil for 12V system
I am getting closer to firing up my fresh 59Y engine.
I am runnng a crab points distributor from Bubba. What coil is recommended ? I want to run one with internal resistance. I have a Petronix 40611 with 1.5 ohm resistance here from an older project. Will that work OK ? I seem to remember an Echlin IC7 was what I used years ago but that was for 6 volts. Thank you. |
12-10-2018, 11:44 PM | #2 |
Re: Proper coil for 12V system
I found another post on the exact subject.
I took Bubba's advice and rdered the blue Bosch coil from Amazon. Thanks Fordbarn. |
12-11-2018, 08:26 AM | #3 |
Skip can wind any of the Ford 1932 to
1948 coils to 12 volts NEG ground if you want to keep the Ford look. G.M.
www.fordcollector.com |
12-11-2018, 10:19 AM | #4 |
