12-05-2018, 07:13 PM | #1 |
aftermarket oil filter kit
so after having the pan off for the first time ever, and seeing all the crap in the bottom, I'm thinking about adding one of those oil filter kits my question is, are they kinda all the same? some better than others??
12-06-2018, 06:54 AM | #2 |
Re: aftermarket oil filter kit
The search function is your friend
https://www.fordbarn.com/forum/showt...ght=oil+filter https://www.fordbarn.com/forum/showt...ver+oil+filter https://www.fordbarn.com/forum/showt...ver+oil+filter Last edited by brokenspoke; 12-06-2018 at 07:03 AM. |
12-06-2018, 07:10 AM | #3 |
12-06-2018, 09:44 AM | #4 |
12-06-2018, 10:01 AM | #5 | |
Good Day! |
12-06-2018, 10:39 AM | #6 | |
12-06-2018, 01:12 PM | #7 |
Ford engine green looks pretty good too.
12-06-2018, 01:28 PM | #8 | ||
Beater, you've been thinkin' a long time. Your quote from over 2 years ago... in this thread. https://www.fordbarn.com/forum/showt...ver+oil+filter Quote:
12-06-2018, 11:09 PM | #9 |
well I don't wana just jump on the band wagon, right away Y-Blockhead
12-07-2018, 03:31 PM | #10 |
I have used the filter that screws on to the valve cover on 3 of my cars but I have a spare engine on a stand on which the filter is mounhted non a bracket beside the motor. Oil is taken from the side of the block just above the oil pump and returned to the timing gear cover. Not sure I like that one as much and I don't know what filter should be on it. For simplicity, it would be good if I were able to use the same one as the others. (Z9)
12-08-2018, 09:54 AM | #11 | |
Try one of the filters from your other cars, it might just fit.
12-08-2018, 05:18 PM | #12 |
The Z9 fits the base OK but there is more to selectiong the right filter than that. For simplicity, I think I'll run with the Z9. I'll be able to do a bulk buy deal, too!
12-09-2018, 10:20 AM | #13 |
Here's an interesting old thread about oil filter kits, particularly see post #8
https://www.fordbarn.com/forum/showt...ote+filter+kit
12-09-2018, 04:24 PM | #14 | |
