08-10-2018, 07:24 AM | #1 |
1930-31 Front Apron Tool Box
HELP please! I need help from someone who has installed the tool box shown.
I need closeup photos of the support brackets, of the tool box shown, that are attached to a 1930-31 Model "A" so I can determine the hardware I need to buy. Please post some pictures here or email them to me at [email protected] A search of the Fordbarn yielded no joy in my quest to learn about this tool box installation. I do know that the apron attachments screws are 1/4-28, and it appears that there are a lot shim washers needed and much longer screws / bolts necessary to get the support brackets in proper alignment.
Bob Bidonde |
08-10-2018, 07:37 AM | #2 |
Re: 1930-31 Front Apron Tool Box
It looks like it might use the screws holding the front apron to the frame horns.
Sorry didn't see last part of your . Check out Bratton's: https://www.brattons.com/metal-tool-box.html Last edited by MickeyT; 08-10-2018 at 07:47 AM. |
08-10-2018, 08:18 AM | #3 |
I have that box on two of my A`s , no extra hardware is needed. when you install the side brackets remove the nuts and lock washer on your front bumper brackets install the brackets install the nuts and lock washer but do not tighten them. now install the box there is four screws that go down inside of the box. now you can tighten all the bolts and nuts. I added a nice little bracket to hold the lid open.
08-10-2018, 12:02 PM | #4 |
JW, you have the correct way to go. My confusion was the location of the brackets. As you say, they pickup the bumper arm attachments and not the screws holding the apron on.
Shortly after posting this thread, a friend sent me some photos of his car and as happenstance would have it, it has the tool box.
Bob Bidonde |
08-10-2018, 12:20 PM | #5 |
Can you still hand crank when this tool box is installed?
08-10-2018, 01:45 PM | #6 |
08-10-2018, 01:16 PM | #7 |
I love my front tool box.
08-10-2018, 01:27 PM | #8 |
Bob
I have a front tool box on my 160B sedan. I have the box support bracket on the outside of my front bumper brackets, The 4 bumper brackets bolts hold the support on. No, you cannot use a hand crank to turn over the engine with the box installed.
Bill Cilker, Jr Unrestored 190A Victoria 45B, 160B & 189A Victoria Association President |
08-10-2018, 02:21 PM | #9 |
I must confess that I have only been involved with these in actual use on a couple of vehicles (-seen them on many, just not been involved with a couple) however the issue I saw in both examples was you could not have placed the stuff inside both of those tool boxes any better with a dump truck. As I recall, neither driver could locate what they thought they had inside. Since both of these were not being used as a tool box but more of a catch all, my question to others is just exactly what do you carry in these that is such a necessity to have?
08-14-2018, 11:47 AM | #10 | |
I know one Second Amendment Model A guy that keeps a loaded 1930s pistol there.
08-14-2018, 12:06 PM | #11 | |
And I'm not referring to this true American Oldboy: https://www.youtube.com/watch?v=U7i9HcheVio
08-10-2018, 02:35 PM | #12 |
I have the smaller, more streamlined tool box (on the car when I bought it).
I carry a small bottle jack, a wheel chalk, two pieces of 4x4 wood , some rags, a lug wrench and a small assortment of tools. And no you can not use a hand crank on this type either. https://www.snydersantiqueauto.com/tool-box Last edited by Y-Blockhead; 08-10-2018 at 02:48 PM. |
08-10-2018, 03:14 PM | #13 | |
The link page says: "The box does block the crank hole in the radiator shell."
08-10-2018, 03:34 PM | #14 |
Look at my picture... You think you can get a crank in there? I wrote "And no you can not use a hand crank on this type either
08-10-2018, 06:20 PM | #15 | |
You're right, sorry.
08-21-2018, 05:40 PM | #16 | |
08-21-2018, 08:10 PM | #17 |
Synchro99- If you put a 3/4" drip lip on the bottom side of the lid, surrounding the box, but not visible when the lid is closed, the rain will drip off the lip and can't get into the box. Then you won't need to make a cover. You should still drill a couple of 1/8" holes in the lowest part of the box, just in case. Weatherstrip on the top edge of the box won't hurt either.
08-10-2018, 06:53 PM | #18 |
Easy to cut a spare crank handle and weld a large nut on the end. Match the grille hole with one in the box with a rubber plug and you can crank the engine over. I never tried to start the motor but it’s probably possible.
08-11-2018, 06:17 AM | #19 |
Good idea! divcoone
08-11-2018, 07:04 PM | #20 |
I carry 2 gallons of gas, a pair of coveralls ,a quart of oil, a roll of paper towel,and a pair of gloves. Any of the long tours where I may need gas before the rest, I can pull over and add if needed. I don't want to put the gas in my rear trunk,where it may cause a smell. Works for me.
