09-16-2016, 02:24 PM | #1 |
1933-'34 Torque Tube Dimensions
For a V8 Torque Tube
I've searched and searched, and there are seemingly dozens of threads that touch on this subject, but NONE I find seem to be "balls-on"-positive with an EXACT overall length, from the bell, to the end of the rear flange. I also need the ID of the big hole in the center of the rear, 6-hole flange. I do know that the length is going to be in the neighborhood of 61-3/4" to 61-7/8". So, does anyone have a relatively clean one that they could lay a tape measure on to get me an EXACT length to the nearest 1/16"? I could also really use a CLOSE measurement on the Inside Diameter of that rear opening at the flange. I'd really appreciate anyone that can take the time to do this for me. DD Last edited by V8COOPMAN; 09-16-2016 at 02:55 PM. |
09-16-2016, 02:52 PM | #2 |
Re: 1933-'34 Torque Tube Dimensions
I don't have one to measure but you should post if you want a 4 banger or V8, they are different.
Charlie Stephens |
09-16-2016, 02:54 PM | #3 |
Coop, I am sure you seen this but? Bruce the difference between 4 cyl and V8. Scroll to his post.
http://www.jalopyjournal.com/forum/t...e-tube.335083/ Ok I see you added V8 |
09-16-2016, 02:57 PM | #4 |
Charlie.....I knew that, and can't believe I forgot to note a V8 tube....which is LONGER by 1-1/2". Thank you, my friend! DD
09-16-2016, 04:02 PM | #5 |
My original 34 torque tube is 1571mm overall (sorry don't have an imperial tape handy) the flange ID is 67.39mm or 2 and 21/32 hope this helps
09-16-2016, 04:50 PM | #6 |
09-16-2016, 07:29 PM | #7 |
For 1933-1934 Fords, regardless of what engine they had, 4 or V8, they were both built on exactly the same chassis & wheelbase. The difference in length is only in the Drive Shafts, to accommodate for the longer 4 cylinder engines and slant of the Radiator.
The length of the Drive shaft in the V-8 = 60 5/32” while the Drive shaft in the 4 cylinder = 58 7/16” It follows that the Tube on the 4 cylinder was shorter by same amount. |
09-16-2016, 09:20 PM | #8 |
Vince Falter has information with the info, but he has marked the lengths as "approximate" dimensions.
http://www.fordgarage.com/pages/model46rearsupport.htm Shows 4 cylinder torque tube approx 60-3/16" and V8 approx 61-13/16" long.
Don't never get rid of nuthin! Last edited by PeteVS; 09-17-2016 at 06:50 AM. Reason: Added dims from Vince's page. |
09-16-2016, 10:07 PM | #9 |
Hi all; Not to be picky, but that late '32 is identical to a 33/34, but again a different tube and drive shaft length. I believe that there are three lengths to look out for. Newc
09-16-2016, 10:31 PM | #10 |
Hi there, I have measured two 1934 V8 torque tubes in the past and my notes say 61 13/16" long. In metric 1571 mm. Regards, Kevin.
09-17-2016, 11:00 AM | #11 |
Big THANKS to all of you's guys for the very timely info, and your efforts. DD
09-17-2016, 04:33 PM | #12 |
As Kevin says; 61 13/16 in. I just changed mine and that's the measure for the longer, (V8), torque tube.
Doug. |
