04-15-2014, 11:38 AM | #1 |
Howan i keep my whte wall from yellowing
Does any one no of a good product to keep my white walls from yellowing every couple of weeks the tires that are not even 2 years old turn . I use the white wall cleaner from crooker tire ,they clean up quick but the older tires on my other car do not require as much attention !!!
04-15-2014, 12:20 PM | #2 |
Re: Howan i keep my whte wall from yellowing
paint them black. end of problem and a significant upgrade......
our next Model A is out there in the unknown...... |
04-15-2014, 01:09 PM | #3 |
I think all we can do is just scrub after each trip. Unfortunately, they will yellow due to pollution, maybe something like armor all to protect from UV sun light.
Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
04-15-2014, 01:18 PM | #4 |
Haha that's what I was thinking...Although Dusty might pipe in that if you paint your fenders green the yellow patina is no problem since the colors go together nicely...
Aaron in Tacoma (although still a Montana hillbilly at heart ) |
04-16-2014, 10:19 AM | #5 |
I usually use SOS pads to keep them clean. I only do it twice a year. Maybe its something in the cleaner that turns them yellow after time. SOS works great.
04-16-2014, 04:47 PM | #6 |
04-16-2014, 05:31 PM | #7 | |
I find that Beach White keeps the WWs white for for a long time. Spay it on and power spray it off, nice and shiny white....goes good with green fenders as well dusty |
04-16-2014, 06:52 PM | #8 |
I use Simple Green and a plastic scrub pad on my whitewalls. Works very well. Coker does not recommend using products like Bleach White. I used to use it on white lettered tires, but didn't want to take a chance on my new whitewalls.
04-17-2014, 07:00 AM | #9 |
your white walls will always yellow due to leaching of chemicals into the white material,the better tires have a butyl lining to stop chemical leaching.
04-17-2014, 07:38 AM | #10 |
Don't use any armor-all type products on the tires this will cause them to yellow as well
04-17-2014, 08:45 AM | #11 | |
04-17-2014, 09:09 AM | #12 |
I have used a product from marine suppliers called spray 9 and it got my WW's clean and white with no effort. It is the best all around cleaner that I have ever tried.
04-17-2014, 09:21 AM | #13 |
I use a pressure washer and VERY hot water, diesel hotsy, works great!
