10-11-2019, 02:21 PM | #1 |
Helmet - condensor (vertex)
I have done this before but had to do another one today, this is a discussion and lesson on how to , not for sales etc. I dont like doing them and dont have the extra time , so if ya want one i can sell you a new Vertex unit ( .36 MFDs with lifetime warranty) perfect for the helment coils etc....and you can do it yourself.
I cut apart a old vintage condensor for the early round top three hole coil. Note the terrible connection at end of condensor and side slide strip ( ball of tin foil in end for connection) This one was still damp inside and may have worked very well ???? Use a little flux to solder the ground connection between vertex and old case ... I use a 8/32 allen to allow me to use a wire connection inside the coil housing , just ike stock. Roll wire into coil and its a stock looking condensor..... Never seen a defective Vertex Mag Tech condensor.......??? |
10-11-2019, 03:52 PM | #2 |
Re: Helmet - condensor (vertex)
I've not mentioned this to you before, I admire your passion , skill , knowledge and the time you spend sharing it .
Thank you ! |
10-11-2019, 04:20 PM | #3 |
Well said - ditto
Thanks Andy 1952 F1 |
10-11-2019, 06:58 PM | #4 |
