01-16-2016, 09:26 PM | #1 |
moderd seats
Due to health problems I need to install modern seats in my 4 door (power would be best).Any suggestion as to what will fit? Thanks
01-17-2016, 12:45 AM | #2 |
Re: moderd seats
Two threads on the same subject is not a good thing,
Contact Bill Williamson for details, https://www.fordbarn.com/forum/showpo...26&postcount=2
01-17-2016, 09:03 PM | #3 |
Re: moderd seats
Posting two threads was not intentional.I only ask for asistance with solving a problem.
01-18-2016, 08:55 AM | #4 |
Re: moderd seats
If you're installing modern seats, you might want to also think about adding seat/shoulder belts at the same time. There are several posts on the forum to give you ideas.
Glen
'31 Model A Deluxe Roadster '31 Chrysler Model 70 Sedan '88 Pontiac Fiero GT '36 Auburn Boattail Speedster replica |
01-18-2016, 09:24 AM | #5 | |
Re: moderd seats
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
01-18-2016, 01:30 PM | #6 |
Re: moderd seats
Charlie Stephens |
01-18-2016, 01:52 PM | #7 | |
Re: moderd seats
I used 90's era Honda Prelude seats. They are narow enough to fit 2 in the front easily. They are 6 way adjustable but not power. Later model may be. The thing I like about them is they have adjustable kidney pads on the side. Another nice thing is the original front mounts can be used. You will have to fab rears. I can change back to the original seats in 15 minutes. |
01-18-2016, 02:10 PM | #8 |
Re: moderd seats
Try searching, "RACIN' SEATS". I typed a step by step article on the installation & where I got the stuff.
Bill W.
01-19-2016, 01:49 AM | #9 | |
Re: moderd seats
Bill, I did the search and cannot find your post on where you found the parts and how you assembled them.
What's right about America is that although we have a mess of problems, we have great capacity - intellect and resources - to do some thing about them. - Henry Ford II Last edited by Mike V. Florida; 01-19-2016 at 02:00 AM. |
01-19-2016, 06:52 AM | #10 |
Re: moderd seats
I haven't had COFFEE yet, but I'll try:
They're replacement Bar Stool Seats, mounted on 3/4" plywood panels. Under them are swivel mounts I found @ Bass Pro Shop & they fit the built-in seat nuts perfectly. Bottom panel has a piano hinge, at the front, mounting it to the seat riser, allowing the seats & panel to open up to the tool storage area. Gregg, (RIP) mounted an adjustable length bicycle kick stand under it, to hold it open. They gave me QUITE a lot of extra leg room & I sit about 3 or 4" lower. Also gave a lot more room to get your feet in past the "A" post, as it doesn't hang over the seat riser, like the wood spring platform did. NO BODY mods & can be changed back to stock seating in about 10 minutes. To get more room to get his feet in, with stock seats, one Guy cut off about 4 or 5" from the front of his seat platform & his springs. (Of course, that DIDN'T give him more LEG ROOM.) Bill W.
"THE ASSISTANT GURU OF STUFF" Last edited by BILL WILLIAMSON; 01-19-2016 at 07:04 AM. |
01-19-2016, 10:32 AM | #11 |
Re: moderd seats
Here's Bill's seats:
