01-20-2019, 02:52 AM | #1 |
Speedo goes backwards
Speedo only works in reverse
Hello any help much appreciated I have a recently restored 1934 Ford Deluxe 5 Window Coupe and the speedo has never worked in forwards direction but does work in reverse. I disconnected the cable from drive worm on top of the enclosed tail shaft and used a battery drill to spin the cable. The speedo works in the anti clockwise direction but that is when you are in reverse. Do i have the incorrect speedo ? Can I change the direction the cable spins? Is it possible to change the direction of the drive gear on the tail shaft ? Cheers Chris |
01-20-2019, 03:02 AM | #2 |
Re: Speedo goes backwards
If you have the turtle on the torquetube turned 180degree it goes the wrong way...if i´m not having a before coffe moment...
01-20-2019, 03:46 AM | #3 |
No coffee required. Turning the speedo drive (turtle) on the torque tube 180 degrees will reverse the direction of rotation of the cable. In this case it will un-reverse the cable rotation.
Mart. |
01-20-2019, 05:08 AM | #4 |
Thanks i will give it try
I had thought of that but the worm drive in the turtle is angled so I didn’t think it would mesh with the drive if i turned it 180. I will take it off again and have another go. Keep you posted |
01-20-2019, 03:31 PM | #5 |
the gear turned 180 simply puts the shaft output end on the other end, making the speedo cable turn the other direction. I did this same thing putting mine together.
01-20-2019, 06:57 PM | #6 |
01-20-2019, 09:45 PM | #7 |
Maybe you put the body on the frame backwards.
01-21-2019, 12:56 AM | #8 |
Now that's funny!
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
01-21-2019, 05:45 AM | #9 |
01-21-2019, 04:28 PM | #10 |
Scratch the paint and see if it disappears. If it does, you have a special car. Just ask Arnie Cunningham. Oops, I guess that is not possible.
I dig coal, which provides motivation for EVs. |
01-22-2019, 07:47 PM | #11 |
I thought this was going to be the joke about the two European guys on the beach and the potato.....
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
01-23-2019, 12:58 AM | #12 |
No, the potato was the two lawyers wearing the Speedos..... just to bring it back around
Seabright Hot Rods |
01-24-2019, 07:02 PM | #13 |
If the drive gear is a bevel cut gear, turning it 180 deg. will destroy the driven gear. They don't work so well like that. Maybe a straight cut gear would work, but not a bevel cut one. Al
01-25-2019, 03:39 AM | #14 |
Grumps, that's not right. 90 degrees, yes, 180 degrees, no.
The turtle can only be rotated 180 degrees so it is ok to do so. In fact, it is already working 180 degrees from the correct position, hence the speedo only registering when the car is going in reverse. Mart. |
01-25-2019, 04:16 AM | #15 |
Maybe it’s like the old Australian saying the toilets flush the other direction.....
01-25-2019, 04:33 AM | #16 |
So all australian speedos work anti clockwise then...just to be in sync with the flushing...
01-26-2019, 12:44 AM | #17 |
if you are down under, which way is up?
01-26-2019, 01:10 AM | #18 |
Be sure to ask the next Aussie you see wearing his speedo backwards. you may then liven up the conversation with your observation of which direction the water swirls in an Aussie toilet.
Alan |
