Old 01-23-2017, 09:04 PM   #1
Beauford
Default Rear Brake Adjustment Wedge
I have screwed the vendor hub puller just about all the way tight. Drum is about 1/2 inch off backing plate but will not let loose. I assume the brakes are too far out. The wedge is rusted solid. I have the tool and put a hammer to it both ways and it wont budge the adjusting wedge. Any thoughts? Too late to hammer with everyone asleep.
Beauford is offline   Reply With Quote
Old 01-23-2017, 09:08 PM   #2
fundytides
Default Re: Rear Brake Adjustment Wedge
Leave the nut loose and drive around the block
fundytides is offline   Reply With Quote
Old 01-23-2017, 09:13 PM   #3
Bob C
Some times if you turn the drum as you pull it will help release it from the shoes.
Bob
Old 01-23-2017, 09:13 PM   #4
Beauford
Fundy, I would but the car is completely apart! Maybe I could borrow the neighbors horse??? LOL
Old 01-23-2017, 09:15 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
Are you saying the hub is loose from the taper, but the brake shoes are holding the drum? I had that problem once and had to decide which part goes to the scrap pile. I don't recall if it was the shoes or the drum that gave up first, but it sure was a fight.
Old 01-23-2017, 09:27 PM   #6
Beauford
Tom, no not loose yet. Tight as a tick. I can't think of anything other than the brakes holding. The wheel would turn when I first got it but would grab in a spot...
Old 01-23-2017, 09:34 PM   #7
1crosscut
1crosscut's Avatar
If you push the drum back in place can you turn the drum then? If so you may have a build up of grease and grime that the shoes are catching on. Take a propane torch and go round and round and round.... the drum to soften the build up and expand the hub a bit and then give it another go.
Dave
It'll feel better when it quits hurting.
1crosscut is offline   Reply With Quote
Old 01-23-2017, 09:34 PM   #8
Mitch//pa
Screw the nut back on the axle enough to protect the axle stub and threads at the end. Wack the center bolt of the puller, tighten, wack, tighten, wack. Something will give.. put ATF on the puller threads
Eat more wheaties
Old 01-23-2017, 09:36 PM   #9
Beauford
1crosscut, yeah I can see in between where the adjusting wedge is there is a bunch of sh@t in there. Black so looks like grease and grime. Car just sat in the elements too long but hell or high water it will go down the road again!!!
Old 01-23-2017, 09:38 PM   #10
Beauford
Damn it Mitch..I have enough fiber from this morning! LOL I need to stay in garage and not on the toilet!
Old 01-23-2017, 10:09 PM   #11
Beauford
I assume it is pulling on the brakes, yes??
Old 01-23-2017, 10:10 PM   #12
Beauford
no wonder the drag in one area when I first spun that wheel....
Old 01-23-2017, 10:27 PM   #13
PatrickGrant
PatrickGrant's Avatar
Beauford, is that your sock or a clean rag on the right, behind the backing plate ?
PatrickGrant is offline   Reply With Quote
Old 01-23-2017, 10:32 PM   #14
Beauford
Pat..its my sock. HAHAHAHA...that's how I roll! I do have safety glasses though.
Old 01-23-2017, 10:39 PM   #15
A31Woody
A31Woody's Avatar
I have the same "work boots"
Our 1931 Station Wagon: Originally restored in 1962, redone in the early 1980's, brought back to life in 1997 and refreshed in 2016/2017. Check out the progress at a31woody.com
A31Woody is offline   Reply With Quote
Old 01-23-2017, 10:45 PM   #16
Beauford
Nice! I'm in steel toes 12 hours a day....got to let the dogs breathe unless I'm taking off the flywheel.
Old 01-23-2017, 10:56 PM   #17
Russ/40
Russ/40's Avatar
Hammer on that dislocated brake shoe, and try to get it back where it should be. Where it is, the harder you pull the drum, the more locked on it will be.
Russ/40 is offline   Reply With Quote
Old 01-23-2017, 10:59 PM   #18
Beauford
Thanks, Russ! I'll give that a try first thing in the morning!
Old 01-24-2017, 12:11 AM   #19
Synchro909
Synchro909's Avatar
What Russ said.
I belong to a procrastinator's club but we haven't met yet.
Old 01-24-2017, 12:15 AM   #20
Lee Mitch
Sure looks like service brake sticking. However, if it has an e-brake, is it on? Don't ask how I thought to ask that!
Lee Mitch is offline   Reply With Quote
Thread Tools
Display Modes
