Old 10-14-2018, 06:06 PM   #1
Colonel
Colonel's Avatar
Default Tips to select good Model A wheels
I am going to look at a pile of Model A wheels. Besides the overall condition of the metal, the hub, the spokes and the lug nut chamfer what other things can I do to pick good straight wheels. I won't have access to any special equipment to spin the wheels for example. It's a cash and carry deal - no return policy. All help appreciated.
Colonel is offline   Reply With Quote
Old 10-14-2018, 06:18 PM   #2
Dennis Pereira
Dennis Pereira's Avatar
Default Re: Tips to select good Model A wheels
Roll slowly on a hard surface like concrete they will wiggle and hop if bent .
Dennis in Kelsey ca
Dennis Pereira is offline   Reply With Quote
Old 10-14-2018, 08:15 PM   #3
redmodelt
redmodelt's Avatar
28/29 beads rotted out or full of rust.
Old 10-14-2018, 09:53 PM   #4
Charlie Stephens
If I was in the market for wheels I would make something to spin them. There is a lot of bent wheels out there.
Charlie Stephens
Old 10-14-2018, 10:38 PM   #5
Rich in Tucson
Rich in Tucson's Avatar
Jack up a front wheel, remove it. Mount a prospective wheel. Place gauges to show runout on front of rim and on outside of rim. For gauges all you need are rods mounted in a base so that you can place one rod on the front side of the rim and one on the outer side. The rods ought to meet the wheel at the mid-height of the rim at whatever height you have it above the ground or floor. I have a lead brick that makes a good base but anything heavy will work.
Rich in Tucson is offline   Reply With Quote
Old 10-15-2018, 06:09 PM   #6
Bob-A
Bob-A's Avatar
Thumbs up Re: Tips to select good Model A wheels
The last time I bought some "A" wheels. I took along a rather heavy, but
accurate home-made tool for checking wheel run-out. A Model-A front spindle C-clamped to a metal jack stand. With bearings and a drum properly mounted. Placed the "tool" on a concrete floor and bolted the wheels on using three lug nuts. Very clumsy way of checking a wheel, but tells you what you need to know.
Bob-A
Bob-A is offline   Reply With Quote
Old 10-15-2018, 06:59 PM   #7
Synchro909
Synchro909's Avatar
Bob-A
I made something similar and use it to balance the wheels. It's not sophisticated (but then, neither am I) but it works. I've been to about 65mph on wheels balanced this way and no sign of vibration. I also use it to check runout.
I belong to a procrastinator's club but we haven't met yet.
Old 10-15-2018, 08:14 PM   #8
2manycars
2manycars's Avatar
I made a tool to check wheels by welding a ford pickup axel to a plate,and adding a pointer to check wobble and runout.
Bill
www.brauchauto.com
2manycars is offline   Reply With Quote
Old 10-15-2018, 08:49 PM   #9
Lee Mitch
A friend taught me to use a wrench and tap on each spoke. They should sound the same. A broken one will sound very different. Definitely roll them on hard surface as post #2 says. Avoid deep pitting as even with powder coating they can't be covered entirely.
Lee Mitch is offline   Reply With Quote
Old 10-15-2018, 08:52 PM   #10
Don Turley
Don Turley's Avatar
If you have absolutely no tooling to check them, then lay one on a flat surface, then stack another one on top of it. If it rocks on the one below, then one (or both) of them is warped. Try another one until you get two that do not rock. After that, then roll them on a flat surface and watch for wobble. Of course, having a spindle to rotate them on is best, but at least this method will weed out the worst ones.
Don Turley is offline   Reply With Quote
Old 10-15-2018, 08:57 PM   #11
Ray in La Mesa
RE Lee Mitch: Good tip Lee, sounding the spokes not only tells a broken one but also it tells the tension. Helps you to see if a broken one has been welded as the tension will sing a different note, even if you can't see the weld. All should be the same note,people watching you at a swap meet will either think yo are playing a tune or are crazy.
Ray in La Mesa is offline   Reply With Quote
Old 10-16-2018, 09:22 AM   #12
Afordman31
Afordman31's Avatar
Carry a lug nut with you to check the bolt holes. If the nut sticks thru on the back side the hole is washed out or starting to wash out. If the nut sticks thru the wheel won't tighten and then you would need to use the washers that venders sell.
Afordman31 is offline   Reply With Quote
Old 10-16-2018, 12:57 PM   #13
Dodge
If they are 28/29 shake them and also listen to them as you roll them to see if there is a bunch of rust inside the bead.
Dodge is offline   Reply With Quote
Old 10-16-2018, 01:46 PM   #14
eagle
eagle's Avatar
It all depends on how much is being charged for the wheels. If reasonably priced and you start doing 21 point inspections on them, you might get thrown out on your rear!
Old 10-16-2018, 04:34 PM   #15
Tom Wesenberg
Tom Wesenberg's Avatar
Yep!
And even "junk" wheels are still good for making chairs or yard art. I've seen nice chairs made from junk wheels, and that's why I have saved a few that aren't good for a car.
Old 10-16-2018, 06:57 PM   #16
eagle
eagle's Avatar
Delete
