Old 05-15-2018, 09:39 PM   #1
Lee Mitch
Default 160-B top wood
I have a slant window 4-door with all the top wood in need of replacement. Can all of the wood be replaced with the cowl/firewall section attached to the rest of the body, or does it need to be cut and removed?
I restored a straight window fordor, including all the wood, and am wondering how similar that process is. Thank you all!
Lee Mitch is offline   Reply With Quote
Old 05-15-2018, 11:15 PM   #2
burner31
burner31's Avatar
Default Re: 160-B top wood
By looking at mine I would say yes.
I don't see the need to remove anything other than. the wood.
I am by no means an expert in this field and would defer any advice to more knowledgeable members
Keith
Shawnee OK
'31 SW 160-B
Old 05-16-2018, 05:30 PM   #3
Dick Carne
Dick Carne's Avatar
We replaced the front header in my nephew's slant window with everything still attached. Although tight tolerances, I don't think that it would be necessary to dismantle the cowl section from the main body. Good luck with your project.
Dick Carne is offline   Reply With Quote
Old 05-17-2018, 09:43 AM   #4
Oldbluoval
Oldbluoval's Avatar
The front header cover is tack welded
You have to take the cover off to get a header in and out
