Old 08-10-2012, 07:55 PM   #1
c125bob
c125bob's Avatar
Default Anybody heard of this overdrive?
My picture of the unit under the car was bad but here's the knob on the steering column. The unit has "RICE A" on the housing but no tag or other markings. It is cable controlled and must be disengaged to reverse. If you forget to disengage it, reverse acts like neutral.
Any knowledge would be appreciated !
Bob
1930 Tudor
Chattahoochee Hills, Ga
c125bob is offline   Reply With Quote
Old 08-10-2012, 07:59 PM   #2
c125bob
c125bob's Avatar
Default Re: Anybody heard of this overdrive?
Dang it... picture is upside down, sorry !
Bob
1930 Tudor
Old 08-10-2012, 08:07 PM   #3
Bob C
I just turned my monitor upside down and it looks good.
Bob
Old 08-10-2012, 09:00 PM   #4
c125bob
c125bob's Avatar
Ha ! I'm happy to get it on here upside down or not !
I searched a good bit here and didn't find anything I could tie to the overdrive. I hoping somebody will know something about it or can point me to some info. Also, thanks for fixing the picture !!!
Bob
1930 Tudor
Old 08-10-2012, 09:31 PM   #5
Tom Endy
Tom Endy's Avatar
I suspect the photo is showing a control cable connected to a Borg Warner overdrive modified for a Model A.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 08-10-2012, 09:41 PM   #6
MikeK
MikeK's Avatar
I don't know specifics about it, but if it acts like neutral in reverse, it probably has some type of one-way locking cone or spring clutch. That would allow engagement and disengagement without depressing the clutch, simply take your foot off the throttle. The downside: It is free-wheeling. This means zero engine braking when you let off the throttle. Sounds nice 'till you're on a long downhill and discover what brake fade is all about. If it were mine, I'd be vigilant about dis-engaging it on major hill crests.
Mechanical engineering 101: If you put an adjustment knob, screw, bolt, or tolerance specs on something, some people will immediately fiddle with it. If you mark it DO NOT TOUCH everyone will mess with it.
MikeK is offline   Reply With Quote
Old 08-10-2012, 11:10 PM   #7
columbiA
Sure sounds like a BW overdrive to me.Not the best OD for an"A" because of the free wheeling when in OD.
columbiA is offline   Reply With Quote
Old 08-11-2012, 12:00 AM   #8
jrapose
jrapose's Avatar
Gee....Must be my wild side..but I like the free wheeling feature...it takes all the buzz out of the winshield when you decelerate... I put brake bands on the drums and that improved the braking by 30% I am told...sure stops well...plus, I like the Borg-Warner unit as it is inexpensive and easy to work on...parts are still available...lots ot them still in wrecking yards...
jrapose is offline   Reply With Quote
Old 08-11-2012, 12:19 AM   #9
Jim Huseby
Jim Huseby's Avatar
The BW overdrive, when properly wired, with all components operative, and shifted into its O'D position, only free-wheels when it is below the governed O'D shift-up speed of about 27 MPH. Above that speed, the engine/trans stays solidly connected to the driveshaft , whether accelerating or decelerating, via the planetary set. The governor can be bypassed and then it wouldn't free-wheel at all. I have put hundreds of thousands of (mostly) trouble-free miles on these, but not in A's. I have driven a couple in A's, but the installers and drivers didn't understand the original wiring and function of the unit and they would crash the unit into and out overdrive with the shifting cable (and think they were doing it right). There is a problem with the free-wheeling, though, and that is the danger that a blown fuse in the unit or an electrical problem will put it into free-wheeling mode, but it then can be manually shifted out of O'D, in which position it can not free-wheel. However THAT process is dangerous to the unit when the car is moving. So,yes, if you're not BW O'D techy, maybe better choose something else.
Jim Huseby is offline   Reply With Quote
Old 08-11-2012, 01:57 AM   #10
sturgis 39
I thought about buying a BW unit. Then I thought about the wife driving and the free wheeling. I think she would panic and probably have a wreck.
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED
Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread.
sturgis 39 is offline   Reply With Quote
Old 08-11-2012, 05:31 AM   #11
c125bob
c125bob's Avatar
You guys are the best ! Thanks, I have some learning to do. Haven't had the car a week, first Model A ever, learning as I go. So...... anybody willing to give me a short run down on how to use the overdrive ? I mean like step by step instructions ? So far my top speed has been 35 and I didn't try the overdrive. I understand about the free wheeling and am glad I chose to ask questions before learning it the hard way ! I'll try to get a better picture of the unit today.
I appreciate your willingness to help me get started with the wonderful car.
Bob
Bob
1930 Tudor
Old 08-11-2012, 06:30 AM   #12
Aerocraft
Aerocraft's Avatar
How about a picture of the OD unit? It is very easy to ID a BW. Gar Williams
Aerocraft is offline   Reply With Quote
Old 08-11-2012, 09:42 AM   #13
miss victoria
what year and model of cars did come in,
miss victoria is offline   Reply With Quote
Old 08-11-2012, 11:07 AM   #14
Tom Wesenberg
Tom Wesenberg's Avatar
Most all Studebakers had B/W overdrives.
Old 08-11-2012, 12:29 PM   #15
CarlG
CarlG's Avatar
50's Fords also had them. My Dad had a 52 & 56 Ford & I had a 53 Merc that all had BW OD. Once I needed some parts for my Merc OD, and they came from a Studebaker.
Old 08-11-2012, 01:22 PM   #16
c125bob
c125bob's Avatar
I finally got a decent picture of the unit. The car is a 1931 Special Coupe and the overdrive was on it when I bought it. Not knowing anything about it I haven't tried to engage it when the car was moving. I did try it sitting still and saw that reverse acts like neutral when it's engaged.
I found some info at this link http://www.fordification.com/tech/overdrive.htm but it refers to electrical activity and wiring etc. My unit doesn't have any connections on it anywhere for wiring. The lever operates smoothly and there is another connection for a cable driven lever. I don't have a clue what that is !!
I'm all ears folks, anybody recognize it or know anything about it ?
Bob
1930 Tudor
Old 08-11-2012, 02:00 PM   #17
Keith True
Keith True's Avatar
Those BW units were used on dozens of different vehicles.I've had quite a few of them.The latest was in a 71 Ford pickup I had,I still have one in a 54 Studebaker.That cable setup eliminates the electric parts.Where that post sticks out in the left side of your picture is where the solenoid would mount.That post is a unit made for the conversion,it gets rid of the electrical parts.I had one just like it.Same cable conversion and all.It worked nicely,but it was a 33% overdrive and that was too high for me.I took it out and sold it.Maybe you have it now.
Keith True is offline   Reply With Quote
Old 08-11-2012, 02:20 PM   #18
c125bob
c125bob's Avatar
Ha Keith, maybe I do ! Now, will you tell me how to work it? How does it shift in and out? Can the car be moving or do you have to set it before taking off?
Bob
1930 Tudor
Old 08-11-2012, 03:00 PM   #19
sturgis 39
I have an under drive transmission from a 29 "AA" Ford truck. They are usually called a dual high transmission. I have been thinking of turning it end for end an making a poor boys overdrive. Has anybody tried this conversion.
Old 08-11-2012, 03:26 PM   #20
Dodge
Yes Sturgis 39,
Its been done, there is a little about it on the web and a couple of pictures. It is supposed to work well and shift nicely on the fly. But noisy. I have one I am going to
to it in a Model A Powered speedster.
The race group we run with won't allow a Mitchell or a Borgwarner, but the turned around AA unit is ok.
Dodge
Dodge is offline   Reply With Quote
Thread Tools
Display Modes
