Old 12-04-2016, 02:39 PM   #1
ModelAJim
ModelAJim's Avatar
Default Can anyone validate some frame dimensions?
Anyone have a bare frame they can easy validate these measurements? See attached plan. Wheelbase should be 103 1/2 right? Also. Looking for distance from center of front axle to the front frame where it begins to taper and the same from centerline of rear axle to start of the rear taper. I appreaciate it guys! The Wescott plans i hear are not accurate. Thanks!
ModelAJim is offline   Reply With Quote
Old 12-04-2016, 03:16 PM   #2
Manager
Manager's Avatar
Default Re: Can anyone validate some frame dimensions?
Centre line to centre line 103 1/2 centre line to front taper 22 5/8 centre line to rear taper 33 7/8 Those widths seem to be right but I think the 49 1/2 to the bend point is way out. I have 52 7/16 but that's measured paralell to the rail so it would be slightly less but not 2 11/16 less I wouldn't think. Maybe double check that one?
Manager is offline   Reply With Quote
Old 12-04-2016, 05:52 PM   #3
SteveB31
SteveB31's Avatar
Go to wescottsauto.com frame measurments from 1909-0948.. Click on Tech. All the frame specs from 1909-1941 are on there, and you can print them out .
Steve @ Bert's
SteveB31 is online now   Reply With Quote
Old 12-04-2016, 08:04 PM   #4
ModelAJim
ModelAJim's Avatar
Thank you!
Old 12-04-2016, 09:16 PM   #5
Manager
Manager's Avatar
Some off Wescotts measurements on the A frame are wrong. They don't even add up. The 32 one seems to be fairly right though.
Also I checked and the 52 7/16 I gave you along the rail from front centreline to bend point is right.
Old 12-05-2016, 07:12 AM   #6
ModelAJim
ModelAJim's Avatar
Great! Thanks again!
Old 12-05-2016, 01:03 PM   #7
Res731
Res731's Avatar
Thee was a whole thread on dimensions. Im trying to decipher the correct ones to use.
https://www.fordbarn.com/forum/showth...ight=dimension
Res731 is offline   Reply With Quote
Old 12-05-2016, 07:51 PM   #8
ModelAJim
ModelAJim's Avatar
Thatss the point. Wescotts have been said alot that the measurements are not accurate. I would not use any. I want accuracy so that i can make a set of framerails.
Old 12-06-2016, 06:12 AM   #9
Manager
Manager's Avatar
Hey Jim just to clarify the P.M. looking at your drawing now, that rear crossmember should be 7 1/2 inches not 9. That 9" would be correct if it were to the bottom of the main frame before it tapers. It's 5" from the top off the frame. The frame is 2 1/4 at the back.
Old 12-06-2016, 04:07 PM   #10
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Then you really need to purchase an A-5005-* print from the archives. I own three of the frame prints, and I can tell you there are major discrepancies with what numbers are floating out there. I suspect many of those were reverse engineered (drawn), and as such that is where the mistakes came from.
File Type: jpg A-5005-C_FrameAssembly_07-11-1930_1of2_v2.jpg (42.6 KB, 52 views)
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Thread Tools
Display Modes
