11-06-2016, 02:58 PM | #1 |
Need 1936-48 Rear Axle 11-Tooth Pinion Gear
City:
Richland
State:
WA
Either 10 or 6 spline as can change the drive shaft.. Someone cut off the drive spline end on a set I have and want to take a chance on setting up a non matched set of 11-39 rear axle gears. Some rear noise would be better than extra engine noise at freeway speeds. If you have one still with the housing or with a pitted or a missing ring gear that is OK also.
11-09-2016, 04:28 PM | #2 |
Re: Need 1936-48 Rear Axle 11-Tooth Pinion Gear
Still looking. If you have an old pinion banjo carrier around, count the teeth on the gear and maybe it is the 11 tooth one I need.
11-25-2016, 10:02 PM | #3 |
