Old 10-18-2016, 08:57 AM   #1
krzewinskibe
krzewinskibe's Avatar
Default anyone know what the rear spare tire carrier is made of?
Found two small cracks after sandblasting and want to TIG weld them up. Not sure if its cast iron or steel....I'm guessing the latter, but makes a difference on what filler/technique I need
why are the repops aluminum
1929 Tudor
krzewinskibe is offline   Reply With Quote
Old 10-18-2016, 10:45 AM   #2
Jim Brierley
Default Re: anyone know what the rear spare tire carrier is made of?
I'm guessing steel too. With your pocket knife, peel a sliver off the carrier. If it comes off as small chips it is cast iron, if it comes off as a sliver it is steel.
Jim Brierley is offline   Reply With Quote
Old 10-18-2016, 11:25 AM   #3
krzewinskibe
malleable iron will sliver too...don't know if they had that kind of iron back then though. I did some digging and I think I'm going to hit an edge with my tig and try filing the weld spot...apparently if it gets super hard its iron.
1929 Tudor
Old 10-18-2016, 11:35 AM   #4
SeaSlugs
SeaSlugs's Avatar
Can ya run a bead in the inside to see how it goes?
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 10-18-2016, 11:38 AM   #5
d.j. moordigian
d.j. moordigian's Avatar
Originally Posted by krzewinskibe View Post
malleable iron will sliver too...don't know if they had that kind of iron back then though. I think I'm going to hit an edge with my tig and try filing the weld spot...apparently if it gets super hard its iron.
You need to post a photo...please.
The first ones were Steele ( that were 3 piece), then came the Cast Iron.
d.j. moordigian is offline   Reply With Quote
Old 10-18-2016, 12:18 PM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
Have you checked for a replacement original part? Bert's has many original parts. 800-321-1931
Old 10-18-2016, 12:23 PM   #7
C26Pinelake
Drill a very small hole or contact Berts. Wayne
C26Pinelake is offline   Reply With Quote
Old 10-18-2016, 12:30 PM   #8
larrys40
I believe they are cast steel. I have mig welded them with good success. Yes, there are replacements out there. Make sure whatever you put on they are not bent. Makes the spare angle not too pretty otherwise.
Larry
larrys40 is offline   Reply With Quote
Old 10-18-2016, 12:45 PM   #9
krzewinskibe
worth my time to try fixing for sanity....gotta save $$$ where I can LOL
1929 Tudor
Old 10-18-2016, 02:55 PM   #10
1Metalbender
I believe I have one for a sedan, little crusty but in good shape otherwise
1Metalbender is offline   Reply With Quote
Old 10-18-2016, 05:54 PM   #11
krzewinskibe
It tests as cast iron....melted a puddle on the back edge, area is now hard as diamond....file has zero bite.
pic attached - note crack at top right of bracket...
so I drilled 1/8" holes at each end of the crack, heated the area around the crack with my oxy torch, tig welded the cracked area with 309L filler a little at a time (peening with an air chisel with blunt pointed bit after each weld section) then dropped in a bucket full of vermiculite I had laying around to slowly cool....we'll see LOL
1929 Tudor
Old 10-18-2016, 06:38 PM   #12
d.j. moordigian
Check next to the weld to see if it's hard(brittle)...there is a chance.
I use "NI-99" too TIG cast iron...works good !
Old 10-18-2016, 06:45 PM   #13
Dick Steinkamp
Dick Steinkamp's Avatar
krzewinskibe,
I like your approach to the hobby. Using your skills to fix the old stuff rather than replacing. Good on you!
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 10-18-2016, 06:51 PM   #14
krzewinskibe
wouldve preferred NI-99, but at the price they want for it...uhhhhh...
alot of good reports using 309L and I had that laying around the shop
1929 Tudor
Old 10-18-2016, 06:53 PM   #15
krzewinskibe
Originally Posted by Dick Steinkamp View Post
krzewinskibe,
thanks....way I figure....my time is "free"
1929 Tudor
Old 10-18-2016, 06:56 PM   #16
Dick Steinkamp
Beyond free...it's entertainment.
Old 10-19-2016, 06:09 AM   #17
macdonge
macdonge's Avatar
The top of the carrier on my 30 roadster was broken clean off back in the 70s and was repaired by brazing. The welder must have done a good job because itś held up this long!
macdonge is offline   Reply With Quote
Thread Tools
Display Modes
