Old 06-27-2016, 02:55 AM   #1
jfreddie
Default Touring cam vs Model B cam
Is there any difference between the two cams, other than the lobe to drive the fuel pump?
jfreddie is offline   Reply With Quote
Old 06-27-2016, 05:48 AM   #2
Kevin in NJ
Default Re: Touring cam vs Model B cam
You would have to be more specific.
Who's 'touring' cam?
Anyone can make up a cam and call it touring. The question is what is the timing and height of the lobes? Is this a regrind or one of new cams you can buy?
A combination of modern fuels and a better understanding of the combustion process allows for more power and efficiency with different lift and timing. The changes can change how the A engine sounds and performs. Also you may need to add compression to be more effective.
When changing cams you also need to know which is the correct size tappet head. With the change in lobe shape you may need a larger head or it wears the cam lobes.
You can learn a lot more by visiting Vince Falter's website. He, as usual, does a great page on cams.
Stipe cam comparisons
Cabriolet and Technical Hints
Kevin in NJ is offline   Reply With Quote
Old 06-27-2016, 05:53 AM   #3
colin1928
colin1928's Avatar
Touring Cam ??? is like touring engine means something different to each person
colin1928 is offline   Reply With Quote
Old 06-27-2016, 08:13 AM   #4
Rex_A_Lott
Yes
Rex_A_Lott is offline   Reply With Quote
Old 06-27-2016, 11:58 AM   #5
jfreddie
You're right. I could have been more specific. I was referring to an off the shelf touring cam from Snyders compared to a Model B cam. Is their cam just a higher lift regrind original or is the profile different, too. The Model B seems to be both different profile and higher lift.
Thanks.
Old 06-27-2016, 12:55 PM   #6
CarlG
CarlG's Avatar
Snyder's B-6250-N Camshaft they list in their catalog is a Stipe IB330, or at least they were when I bought mine several years ago.
Bill Stipe's description: New Improved "B" 330 (great low end torque excellent Touring
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
CarlG is online now   Reply With Quote
Old 06-28-2016, 10:52 AM   #7
Jim Brierley
The main physical difference is the pump lobe. A touring cam is generally a mild performance cam. The latest factory B cam had .339" lobe lift and makes a great touring cam.
Jim Brierley is offline   Reply With Quote
Thread Tools
Display Modes
