Old 12-08-2015, 07:40 AM   #1
ModelAJim
ModelAJim's Avatar
Default Can you ID a 32 Heavy Axle by its Hub?
Guys, here is a pile of old axles, the one in the lower right where the hub has windows in it, is that definitely a 32 Heavy? Or did they make that style many years. Its been a while since I've been to this place and it was buried. Just saw a pick of a real 32 heavy and it had the same hub...wondering if its worth a trip back. Probably could get for hardly nothing. Thanks!!
ModelAJim is offline   Reply With Quote
Old 12-08-2015, 07:50 AM   #2
Mark T
Default Re: Can you ID a 32 Heavy Axle by its Hub?
Without seeing the axle itself it would be near impossible to say, the hubs could have been changed.
Mark T is offline   Reply With Quote
Old 12-08-2015, 07:52 AM   #3
ModelAJim
ModelAJim's Avatar
If I had to bet, its original...
Old 12-08-2015, 08:29 AM   #4
scooder
The "hub" brake drum with the "Windows" this basic style drum with holes was used through 35, there are width and radial fin count differences, but had the holes. Only the Axle itself will tell you if it's a "heavy" as your calling it.
Martin.
scooder is offline   Reply With Quote
Old 12-08-2015, 08:42 AM   #5
62pan
This is a 32 Heavy.
62pan is offline   Reply With Quote
Old 12-08-2015, 10:10 AM   #6
Fordors
Get a helper and a trailer and go back. There appears to be enough there with lots of possibilities, and where I'm from stuff like that is a rare find these days. Looks to be a frame up on wheels on the left side, is that right?
My school colors are black and blue, I attended the School of Hard Knocks where I received a Masters Degree in Chronic Mopery.
Fordors is offline   Reply With Quote
Old 12-08-2015, 10:13 AM   #7
DavidG
DavidG's Avatar
The brake drum with the "windows" is a '35 given the circumferential ribs. The closed drum is '36-'39.
Given that the '33 front axle has the same center cross section between the spring perches. Without seeing the ends from the spring perches outward, it could be either a '32 or a '33.
Old 12-08-2015, 12:50 PM   #8
ModelAJim
ModelAJim's Avatar
Thanks for the help guys! I'm not sure its really still there, but could make a trip. I recognized the windows on the drum, and was wondering if that was a 32 only type drum....
Old 12-08-2015, 04:44 PM   #9
RalphM
RalphM's Avatar
Lots of good parts, but if Those axles are stored torque tube up and not covered, they can be a solid chunk of rust inside.
RalphM is offline   Reply With Quote
Old 12-08-2015, 06:34 PM   #10
rotorwrench
rotorwrench's Avatar
Good rain water collectors. Kind of like old engines with the hood and air cleaner removed.
Thread Tools
Display Modes
