Old 01-24-2014, 06:33 AM   #1
tiger.1000
Default 32 hood prop made in gt britain
Took a bit of head scratching and doing but here's my solution to an apparently insolvable problem; thus enabling one to fully open the hood and have a mechanism which looks more in keeping than the after-market bolt on kit.
All comments appreciated and I can take it on the chin !
Before you ask.....no chance of damaging louvre No 7 (from the front)
tiger.1000 is offline   Reply With Quote
Old 01-24-2014, 07:16 AM   #2
Deuce-Addict
Default Re: 32 hood prop made in gt britain
Is that a touch up aerosol on the ground to paint in the chips?
Deuce-Addict is offline   Reply With Quote
Old 01-24-2014, 07:21 AM   #3
tiger.1000
A touch-up aerosol ? ......do I detect I hint of "I want one and sorry for doubting you whilst you've been slogging away in your workshop" ?
Old 01-24-2014, 07:25 AM   #4
Deuce-Addict
All joking aside, very ingenius and impressive. I can stop watching for a post on the Wanted ads now for a replacement hood side.
Old 01-24-2014, 07:30 AM   #5
koates
Hi there, Yes, not bad but you can only put one side of the hood up at a time. Guess you would not need it to be too windy either ! I prefer the one that bolts across the radiator rods, as it allows both sides up together when required. Regards, Kevin.
koates is offline   Reply With Quote
Old 01-24-2014, 09:29 AM   #6
tiger.1000
Thanks Kevin !
Rarely would I need to have both sides up at the same time; besides as previously stated, I want to work on the car without bashing my head; thus problem solved.
You may not agree with me but I believe this method looks more like part of the car
as opposed to a "bolt-on".
Wind not an issue as I use my workshop.
Old 01-24-2014, 09:57 AM   #7
itslow
itslow's Avatar
I looks like one could devise a "hidden" bracket that mounts to the inside of the hood side opposite the handle or female latch piece into which the rod fits. This would eliminate the potential for scraping paint or bending a louver.
Mike
Wanted:
- '32-34 Open Cab Pickup (RPU) parts and documents/articles/info
- ARDUN parts
itslow is offline   Reply With Quote
Old 01-24-2014, 10:28 AM   #8
tiger.1000
Mike, good point and I did consider that but was reluctant to
drill, glue or in any way molest the hood panel.
See the photo.....the forked end locates in to the louvre and where it fits I've laid a piece of shiny black insulation tape.
The forks are made of aluminium and are coated 0.040" thick
with black nylon. Believe me.....it works !
Importantly, it's been an enjoyable project and I have satisfied my requirement for something which I needed; does work and if for any reason I don't like it; it's removed in a jiffy. Chances are it'll stay put...
Old 01-24-2014, 11:51 AM   #9
2935ford
2935ford's Avatar
tiger.1000 nice job.....I like it. I have the bolt across but they sure are ugly looking. Yours is much cleaner and looks like it could have come with the car.
2935ford is offline   Reply With Quote
Old 01-24-2014, 12:10 PM   #10
1932BB
Congratulations! You did it! What is the purpose of the copper tubing and brass fittings between the cyl head and the radiator tank?
1932BB is offline   Reply With Quote
Old 01-24-2014, 01:14 PM   #11
Lawson Cox
Lawson Cox's Avatar
Yes, inquiring minds want to know.
Old 01-24-2014, 02:04 PM   #12
tiger.1000
Thanks for the praise ! There was I thinking I'd broken all the rules !
The copper tubing.....I think I opened a thread on this sometime back......fill up the radiator and drive the car. Coolant expands and when it cools it contracts and generally speaking the level is BELOW the top of the radiator. So I removed the rear fixing bolt from the water pump, machined a sight glass assembly out of brass. The small bore copper tube then vents in to the top of the radiator tank.
Open the bonnet (hood) and you have a quick visual check
and off you go !
Simple really !
If anyone's seriously interested I'll load some more pictures of it on this thread.
Old 01-24-2014, 02:13 PM   #13
BILL WZOREK
BILL WZOREK's Avatar
I for one would like to see it!! SERIOUSLY
BILL WZOREK is offline   Reply With Quote
Old 01-24-2014, 02:21 PM   #14
tiger.1000
Bill.....just having my supper. I'll take some photos in a while and put them on this thread
Old 01-24-2014, 02:42 PM   #15
tiger.1000
Sight glass....first four pics....rest to follow
Old 01-24-2014, 02:44 PM   #16
tiger.1000
Best I can do by flash light.....
Old 01-24-2014, 05:21 PM   #17
BILL WZOREK
Very,very nice!!
Old 01-24-2014, 06:05 PM   #18
Henry Hopper
Henry Hopper's Avatar
Tiger, beautiful car, great idea with the bonnet prop and clever trick with the sight glass ....you realise that now you will get ten pages of people telling you that the copper will break ha ha.....
Henry Hopper is offline   Reply With Quote
Old 01-24-2014, 06:40 PM   #19
117harv
117harv's Avatar
Great job on those custom pieces...the car is outstanding.
117harv is offline   Reply With Quote
Old 01-24-2014, 06:44 PM   #20
Fe26
Now that's nifty.
Fe26 is offline   Reply With Quote
Thread Tools
Display Modes
