Old 10-13-2014, 10:02 PM   #1
dave m
Default Dog bones ?
Started rebuilding my front shock links ''dog bones'' on my 35 coupe knocked the rivets out but the rubber replacement balls i got from mac's are too small. Go figure another replacement part that doesn't fit right & they say licensed by ''ford'' ha ha & made in taiwan---- anybody know who sells the correct size rubber balls---thanks
dave m is offline   Reply With Quote
Old 10-14-2014, 10:38 AM   #2
38Tudor
38Tudor's Avatar
Default Re: Dog bones ?
I would and have bought new dog bones. A lot of good vintage ford part dealers have them and they are not expensive.
"Thrifty Sixty"
Ford V8 for 1938
38Tudor is offline   Reply With Quote
Old 10-14-2014, 11:34 AM   #3
J Franklin
J Franklin's Avatar
Stretch that rubber! it is probably metric.
Old 10-16-2014, 08:11 AM   #4
117harv
117harv's Avatar
Too small on OD or ID? If ID, put them in some boiling water for a couple seconds and then put them on.
117harv is offline   Reply With Quote
Old 10-16-2014, 08:19 AM   #5
Tim Ayers
I was thinking the same. You don't want them loose or they will just tear.
Old 10-16-2014, 10:45 AM   #6
JM 35 Sedan
JM 35 Sedan's Avatar
I've done a number of these dog bone links for my '35's using the rubber balls supplied by Drake and Carpenter. Have had no issues with final fit up and assembly of bone halves. Just make sure the balls on the ends of the tapered/threaded studs are in good condition. Never used the rubber balls that MAC's supplies since I stopped doing business with them years ago.
John
