Old 05-13-2020, 04:36 PM   #1
DBSHELTON
Default Distributor Machine Build
Anyone got an old distributor machine in their shop that still works? I would like to check the curve on a few distributors that i have.
DBSHELTON is offline   Reply With Quote
Old 05-13-2020, 06:17 PM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: Distributor machine
Nope, ours disappeared decades ago. very useful machines.
Old 05-13-2020, 07:30 PM   #3
larrys40
I use a Ford heyer unit. Flathead v8’s with universal and longshaft capabilities
Larry
larrys40 is offline   Reply With Quote
Old 05-13-2020, 09:22 PM   #4
Mikeinnj
Mikeinnj's Avatar
You can build your own Distributor Test Machine for under $100.
Here is a link on how to do that,.....http://www.ourdigitalmags.com/public...articleBrowser
Mike in New Jersey
Mikeinnj is offline   Reply With Quote
Old 05-14-2020, 07:28 AM   #5
DBSHELTON
Thanks Mike, I wonder how I could get the photos to show up in the article?
Old 05-14-2020, 01:08 PM   #6
KUDZUVIPER
For DB, click on upper right corner of page (open book), it will take you to the article with photos.
KUDZUVIPER is offline   Reply With Quote
Old 05-14-2020, 02:32 PM   #7
DBSHELTON
Duh, thanks for helping me out.
Old 05-28-2020, 06:58 AM   #8
DBSHELTON
This has turned into a build thread. I may be over thinking this but I have a digital Automotive tester I want to use on my homemade distributor machine to check dwell and RPM. Is says to connect the COM lead to the battery Neg terminal and the V or + lead on the meter to the Coil - terminal. On 6v Pos ground this would this be correct?
Old 05-28-2020, 08:16 AM   #9
Jack Shaft
Buy a timing indicator from the vendors,verify TDC and mark the crankshaft pulley and set the indicator.Install a point impulse tach (cheapie tach and dwell meter) shine timing light on mark and rev engine a mechanical advance distributor should increase 1 degree per 100 rpm,so for instance 20 degrees advance at 2000 rpm.I verify at 1000,1500 and 2400 rpm.If your engine is stock other than the distributor it is very tolerant of timing deviation,in other words a basic check of the curve is sufficient.As you raise volumetric effciency through performance upgrades your timing 'tolerance' gets shorter.But in either case you dont have to get as precise as the article does.
Old 05-28-2020, 09:39 AM   #10
DBSHELTON
Thanks. Still not sure how to hook up my meter correctly.
Old 05-28-2020, 09:46 AM   #11
Jack Shaft
A tach and dwell meter? Black is ground,green(or red)goes to the points side of the coil.
Old 05-29-2020, 04:58 AM   #12
DBSHELTON
That didn't work
Old 05-29-2020, 07:43 AM   #13
Jack Shaft
post a picture of your meter
Old 05-29-2020, 10:52 AM   #14
katy
katy's Avatar
Originally Posted by DBSHELTON View Post
That didn't work
Try reversing the leads.
Play it again Sam.
Old 05-29-2020, 05:59 PM   #15
DBSHELTON
I think my meter is bad. Reads very inconsistent.
Old 05-30-2020, 06:51 AM   #16
DBSHELTON
Found out I had a loose connection in my meter. Correct hookup for Dwell/Tach for 6v POS Ground is Red to Ground and Black to Points.
Old 05-30-2020, 07:22 AM   #17
DBSHELTON
Default Re: Distributor Machine Build
Photos attached
Old 05-30-2020, 07:54 AM   #18
Jack Shaft
My apologies on polarity,I set my car up 12v neg ground.
Old 05-30-2020, 09:01 AM   #19
DBSHELTON
No apology needed. It's all good.
