Old 07-25-2019, 05:56 PM   #1
fftoddster
fftoddster's Avatar
Default temp guages sending units...
So I have a '37. Replacing engine with a '46 with Edelbrock heads. The car is still 6 volt. I do not believe the sending unit from 37 fits in the Edelbrock heads.
The Edlebrock heads have the 1 and 2 wire sending units which I believe are a pipe thread? (Different than the thread on '37 heads?)
So the question is what to do to monitor temperature. hidden gauges under the dash? 6 Volt gauges? Or mechanical gauges? Any recommendations on what brand...?
Thanks for any input.
fftoddster is offline   Reply With Quote
Old 07-25-2019, 06:45 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: temp guages sending units...
there are adapters to fit original gauge bulb into the pipe thread
Old 07-26-2019, 06:26 PM   #3
Kurt in NJ
Kurt in NJ's Avatar
The parts book lists part 01A-10889 --adapter heat indicater bulb ---for use when later engine in 32-37
Old 07-27-2019, 05:55 PM   #4
fftoddster
fftoddster's Avatar
Thanks, that part # may help. I have not had much luck finding it without part #.
Old 07-27-2019, 08:21 PM   #5
aussie merc
aussie merc's Avatar
if youve got both bits any shop that does hydraulics [hoses and fittings] should be able to supply or make you an adapter to suit
aussie merc is offline   Reply With Quote
