Old 06-13-2019, 12:03 PM   #1
Burt Lake Barn
Default Ole 6 volt headlights in a 12 volt system
I have an old ford that has been converted to 12 volt and would like to use some very old headlights that were/are 6 volt. I can get the original bulbs and wondered if someone makes a 12 to 6 volt reducer that I could install for this purpose? I also wondered if anyone is aware of a company that can do minor repairs on these old bucket type headlamps as one lamp has a few brackets missing. I believe they may have been from a 1928 Hudson. The lenses are marked “Parabeam headlamp” and they are 10 inches in diameter. Any info, ideas or information are greatly appreciated, thanks
Burt Lake Barn is offline   Reply With Quote
Old 06-13-2019, 12:22 PM   #2
19Fordy
19Fordy's Avatar
Default Re: Ole 6 volt headlights in a 12 volt system
Give Ron Frances a call and see if they can help you. Pretty sure they will know the answer.
https://www.ronfrancis.com/contactus.asp
Are you a member of the Hudson Terraplane Club? Bet they can help you also.
https://www.hetclub.org/
19Fordy is online now   Reply With Quote
Old 06-13-2019, 12:36 PM   #3
G.M.
Put the 2 new lights in series. Only problem
is when one go's out both are out. Carry
spares. G.M.
www.fordcollector.com
Old 06-13-2019, 02:54 PM   #4
Bob C
What's the number of the original bulb??
Bob
Old 06-13-2019, 02:56 PM   #5
flatheadmurre
flatheadmurre's Avatar
The hightec version of converting 12v to 6v with small losses would be a Switched buck converter...lowtec version a big resistor burning of as much energy as the bulb itself.
Old 06-13-2019, 05:25 PM   #6
Kurt in NJ
Kurt in NJ's Avatar
look at www.classicandvintagebulbs.com
Old 06-13-2019, 06:51 PM   #7
Burt Lake Barn
Thank you all for the great information. I appreciate your responses.
Old 06-19-2019, 05:36 PM   #8
Burt Lake Barn
Sorry for the delayed response. The bulbs that I have are marked as follows:
Westinghouse 1000
5BRP11 32 & 32c. 6-8 V
1927, 28, 29, 30, 31, 32 Lincoln/Hudson NOS
Old 06-19-2019, 05:58 PM   #9
Bob C
The 12V replacement for the 1000 is 1124.
there are some on Epay https://www.ebay.com/itm/New-Box-of-...4AAOxy~iJQ9XpZ
https://www.ebay.com/itm/GE-1124-aut...oAAOSwa29byzQQ
Bob
Old 06-20-2019, 06:49 AM   #10
Burt Lake Barn
Thanks Bob that seems to be the simplest path to take
