Old 08-04-2018, 05:43 AM   #1
roy green coupe
Default Heat from engine inside car
On my 30 coupe I noticed hot air coming into the cab from under the fuel tank at the ends. I found it was coming in at the lower body corners just below the floor and up behind the kick panels . I sealed it up in an effective but not period correct way with insulating foam. It is much cooler inside now, bottom of fuel tank actually feels cool. My question is how was this addressed in the original cars ? Did they have some kind of seal or insulation that would have taken care of this?
roy green coupe is offline   Reply With Quote
Old 08-04-2018, 09:04 AM   #2
Gary WA
Gary WA's Avatar
Default Re: Heat from engine inside car
welting between body/frame, and no seal or insulation was used.
www.whidbeymodelaclub.com
Old 08-04-2018, 09:41 AM   #3
DHZIEMAN
There are some other threads that talk about muffler heat deflectors and also about the exhaust manifold pipe having a heat deflector also. But this is all aftermarket owner fabricated stuff. Plus I think Macs sells a muffler heat baffle.
Others have done as you have and sealed up the floor with insulation, there is a thread I saw on that too! Use the "search" tool.
DHZIEMAN is offline   Reply With Quote
Old 08-04-2018, 09:57 AM   #4
Bob Bidonde
Bob Bidonde's Avatar
Try this fix.
Bob Bidonde
