Old 09-19-2018, 12:27 AM   #1
KarlJS
KarlJS's Avatar
Default Bolt size
Does anybody know the bolt size for the rear light brackets on a 39í 1/2 ton truck? Mine are non existent and Iím wanting to run a tap to clean up the threads. Thanks
KarlJS is offline   Reply With Quote
Old 09-19-2018, 03:49 AM   #2
Mart
Mart's Avatar
Default Re: Bolt size
Mine is a 41 and just has coarse self tappers. If there are little inserts my money would be on them being 1/4 UNC.
You could try a bolt gently and see if it wants to start.
Mart.
Old 09-19-2018, 07:12 AM   #3
JSeery
JSeery's Avatar
I would start with a thread chaser. They can also be used to determine the thread size. If you purchase a set(s) keep in mind that they often come as a set of coarse and a set of fine threads. They are very handy when working on older cars.
Old 09-19-2018, 09:09 AM   #4
Kube
Kube's Avatar
My '40 is 1/4 -20. I'd think '39 would be the same.
"Imagination is a crutch used by those who lack knowledge and intelligence ."
B
. Franklin
Old 09-19-2018, 10:07 AM   #5
bosborn38pu
bosborn38pu's Avatar
My '38 is 1/4 - 20 (w/cage nuts inside).
bosborn38pu is offline   Reply With Quote
Thread Tools
Display Modes
