12-27-2015, 05:13 PM | #1 |
1930 CCPU door glass size
Can some one give me the exact glass size for 1930 CCPU doors? Including the corner radiis?
Thank you! Larry
Good enough.. Isn't. Last edited by Larry Jenkins; 12-27-2015 at 07:57 PM. |
12-27-2015, 07:47 PM | #2 |
Re: 1930 CCPU door glass size
service bulletins page 250 has glass sizes,same as coupe?
www.whidbeymodelaclub.com Last edited by Gary WA; 12-27-2015 at 09:20 PM. |
12-27-2015, 08:40 PM | #3 |
Look in the yellow, hard cover service bulletins.
12-27-2015, 11:57 PM | #4 |
The 30 - 31 coupe glass is a couple of inches or so narrower than the 30 - 31 CCPU. As they both use the same doors, the 30 -31 CCPU and the 30 - 31 Tudor both have the same sized door glass. I tried using the Model A service bulletins for my 31 CCPU for the door glass and for the back window but the bulletins were of no help. They had about everything but what I needed. I ended up measuring the door's window openings for the glass shop and the door glass fit excellent. The glass shop also used my rear window frame for its glass pattern.
12-29-2015, 05:08 PM | #5 |
Just measured door glass out of a 31 tudor which is the same as mid 30 /31 CCPU.
Height 16 3/8" Width 26 3/4" Thickness 1/8" John in weather was cancelled again today Suffolk County England . |
12-29-2015, 05:27 PM | #6 |
12-29-2015, 07:58 PM | #7 | |
Isn't original glass 1/4" thick? (I've read anywhere from 0.220 to 0.250) Larry
Good enough.. Isn't. |
12-30-2015, 09:24 AM | #8 |
Yes I did a double check and it is dead 3/16" thick . This is original plate glass . The edges are ground with a slight domed effect . The upper corners have a tight radius I suppose to avoid a sharp corner . In UK we are now metric and the closest laminated glass is 6mm thick which about 3/16" and works OK .
John in wild and windy storm "Frank" 80 MPH in the north of UK ,heavy rain and floods Suffolk County England . |
12-30-2015, 12:33 PM | #9 |
The Service Bulletins show the plate glass 5/32" to 9/32" and triplex glass
.180" to .200" thick. Bob |
12-30-2015, 12:42 PM | #10 |
That's quite a range for the plate glass:
5/32 = .156 9/32 = .281
12-30-2015, 12:53 PM | #11 |
That's what I though also, maybe it should have been 7/32". If I remember
correctly from other posts there are other errors in the glass chart. Bob |
02-18-2018, 01:53 PM | #12 |
02-18-2018, 01:56 PM | #13 | |
This was added to the post later
