Old 04-05-2017, 07:08 AM   #1
Woodie1
Woodie1's Avatar
Default Speed-o-meter cable lubing
Can the speed-o-meter cable be lubed just by removing it from the drive shaft & pulling it out or does it have to be removed from the dash panel position for lubing? Thanks.
Woodie1 is offline   Reply With Quote
Old 04-05-2017, 07:43 AM   #2
SeaSlugs
SeaSlugs's Avatar
Default Re: Speed-o-meter cable lubing
it slides out the dashboard end, be very careful you dont get it on you or your interior - graphite and grease is VERY hard to get out of cloth....
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 04-05-2017, 08:51 AM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
I use distributor Cam Lube from my OLD, WRINKLED tube. It must be 60 something???years OLD.
Bill Quiet
"THE ASSISTANT GURU OF STUFF"
Old 04-05-2017, 02:28 PM   #4
redmodelt
redmodelt's Avatar
You could lube it by greasing the u-joint housing, when you see grease filling up the speedometer you put too much in! LOL
Old 04-05-2017, 08:40 PM   #5
HammerSaw
CRC brake lube works very well.
HammerSaw is offline   Reply With Quote
Old 04-06-2017, 07:00 AM   #6
dr.j
dr.j's Avatar
Bill Quiet
Geez Bill, I thought you were a little older than that. ha ha ha
Dave A Jamieson
Portland, ON
Canada
1928 Tudor
dr.j is offline   Reply With Quote
Old 04-06-2017, 07:08 AM   #7
Ray in La Mesa
When pulling the speedo cable from the upper end to lube it, feed it into a large zip lock bag then close the zip lock to about 1" to prevent the spread of grease on everything.
Ray in La Mesa is offline   Reply With Quote
Old 04-06-2017, 10:08 PM   #8
1crosscut
1crosscut's Avatar
Very timely post as I'm going to be lubing the speedometer cable on a friends Phaeton tomorrow. I like the ziploc baggie idea.
Dave
It'll feel better when it quits hurting.
1crosscut is offline   Reply With Quote
Old 04-06-2017, 10:19 PM   #9
BILL WILLIAMSON
If you want to know if your cable is KINKYDOED, hold it in a 180 & twirl it with your forefingers & thumbs. It should rotate SMOOTHLY. If it goes "thump-thump" replace it, for a "happy" speedo.
Bill W.
Thread Tools
Display Modes
