08-10-2021, 08:35 AM | #1 |
Dana 44 axle housing leak
I have had a small gear oil leak on a Dana 44 rear axle in our 52 F1. At first I thought it was the fill plugs, but upon inspection last night, I think it’s coming from the housing. We had a pin hole leak show up when the axle was put in epoxy primer. I used some glyptal on the inside and thought I sealed it up, but it appears to still be leaking.
Anyone ever come across a leak like this? Recommendations on repair? JB |
08-10-2021, 09:29 AM | #2 |
Re: Dana 44 axle housing leak
The photo is hard to distinguish what we are looking at there. If that is the input area, the input seal would be suspect.
08-10-2021, 09:57 AM | #3 |
In that photo, the pinion seal area is pointed to the ground. The leak is from a spot right above the webbing in the actual housing. I don’t think it’s a crack, just a casting flaw/pore that goes through the metal into the oil chamber?
JB |
08-10-2021, 04:27 PM | #4 |
You can pin it or possibly seal it but a pin would likely last longer. If it's leaking gear oil from inside then it goes all the way through. |
