10-30-2011, 03:06 PM | #1 |
1928 Model A
I have a leaky zenith 1 carburetor. Has anyone tried the viton tipped needle for the float valve and seat?????????
10-30-2011, 04:29 PM | #2 |
Re: 1928 Model A
With the gas available today, with ethonol, suggest you not use the viton float valve.
Is it possible your float may be set too high ? If so, the fuel in the bowl is higher than the tips of the cap and main jets and will run out; will come out the small hole in the bottom of the carb and collect and drip from the housing bolt. Check the float to determine if it contains fuel, caused by a small hole somewhere in the float; if so the float gets heavy and will not rise and shut the fuel off. If the housing gasket gets wet its probable leaking at the inlet line connection. Ron |
10-30-2011, 07:56 PM | #3 |
Re: 1928 Model A
I've been using modern float valves from Brattons with good results.
10-30-2011, 08:45 PM | #4 |
Re: 1928 Model A
I have been useing the viton tip for 15+ yrs with good results. Ron W
10-31-2011, 07:44 AM | #5 |
Re: 1928 Model A
I just had a subscriber complain about the fuel eating up his float valves. Ethanol is much more caustic than plain gasoline and will attack anything not designed to be used in that environment.
10-31-2011, 08:21 AM | #6 |
Re: 1928 Model A
10-31-2011, 08:05 PM | #7 |
Re: 1928 Model A
Keith, You may have something there. Your comment made me look in my book. It say Viton is NOT for use with acetates, ketones, METHYL ALCOHOL, brake fluids, hot water or steem! Seems it's good for gas but not much else. Now I'm wondering when mine will go bad? Ron W
11-01-2011, 08:45 AM | #8 |
Re: 1928 Model A
Methyl alcohol is not the same as ethanol, they are different chemically. M is typically made from natural gas, e from plant material.
Luck occurs when preparation and opportunity converge. |
11-01-2011, 01:14 PM | #9 |
Re: 1928 Model A
When it was first mandated one of the chain stations in town could not get enough ethanol,so methanol,(methyl alcohol??) was used until they got up to speed.They paid for a LOT of problems.The biggest problem was with brass.It ate brass and some types of rubbers.Since they got with the program there have been no problems with the brass.The oil company rep told me that if my brass parts were turning green in the gas,It was the M stuff,not the E.I melted the floats in a couple of Wisconsin engines,with the first batch they had.They've been fine after that.He also told me the rest of the gas was junk however,and any form of alcohol just makes it worse.He said to use it in two weeks if at all possible.We have all been out of power here now for three days and I have been out getting generators running for some old folks.Some haven't been run for two or three years but I got a half dozen running on the old gas.If they start on the old gas I top them off with fresh,now all of them are running on fresh gas.I've been putting the Seafoam right to them,figuring that if the power comes on they will have some in the system to help until the next time.I've used about 25 gallons of gas in my own generator this time.
