Old 01-01-2020, 09:41 PM   #1
alexiskai
alexiskai's Avatar
Default Stuck side cover for timing gear
One of my long-standing checklist items is to inspect the timing gear. I have no reason to think it's busted, but I'd like to get a sense of its condition. I attempted to remove the side cover to get a look at it, but after removing all the bolts it wouldn't budge.
Any suggestions for how to unstick this cover? Penetrating oil around the edges? Torch?
I'm reluctant to apply a lot of force, both because there's a lot of critical stuff in that area and because it's a good way to get some nasty cuts. I also don't want to remove the main timing gear cover if I don't absolutely have to.
Old 01-01-2020, 09:51 PM   #2
1955cj5
1955cj5's Avatar
Default Re: Stuck side cover for timing gear
You said you removed all the bolts........be sure to remove the one that comes from underneath through the oil pan lip.
I used a deadblow hammer to gently loosen the cover...
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 01-01-2020, 09:52 PM   #3
rogerkb1936
rogerkb1936's Avatar
did you remove the bolt on bottom that comes up thru oil pan?
rogerkb1936 is offline   Reply With Quote
Old 01-01-2020, 09:54 PM   #4
Gary WA
Gary WA's Avatar
Oil pan bolt bottom corner
www.whidbeymodelaclub.com
Old 01-01-2020, 11:50 PM   #5
alexiskai
alexiskai's Avatar
Thanks everyone, yes I did remove all three bolts.
Old 01-02-2020, 01:08 AM   #6
J Franklin
J Franklin's Avatar
A blow from a rubber hammer is how I get things to move.
Old 01-02-2020, 07:40 AM   #7
ryanheacox
ryanheacox's Avatar
Rubber hammer or dead blow should pop it free.
ryanheacox is offline   Reply With Quote
Old 01-02-2020, 08:15 AM   #8
62pan
Isn't there 5 bolts?
62pan is offline   Reply With Quote
Old 01-02-2020, 08:43 AM   #9
Jack Shaft
Get some help,the suggestions you initially made for removing the cover imply your skills lie else where than basic mechanics..please don't take that wrong,even if you do get the cover off a little help in technique will insure it wont leak,its encompasses three gaskets,two of which are partially exposed by the small cover.rip those gaskets and don't assemble it correctly you will pour oil.
Jack Shaft is offline   Reply With Quote
Old 01-02-2020, 09:53 AM   #10
johnbuckley
johnbuckley's Avatar
Removal of the side plate of the timing cover. To remove this undo the two retaining side bolts (7/16th) , the three front bolts ( 9/16th) and the sump nut which also retains it. The sump nut can be difficult to get at especially if the engine splash plates are in situ,- gentle leverage of the plate allows an extra few millimetres
johnbuckley is offline   Reply With Quote
Old 01-02-2020, 10:03 AM   #11
alexiskai
alexiskai's Avatar
If my skills were in basic mechanics I would not be on this forum asking this question; "getting help" is exactly what I'm doing.
Old 01-02-2020, 10:58 AM   #12
johnbuckley
Well said Alexiskai. Good on yer! Unsolicited opinion as opposed to useful advice occurs all too often on forums -even fordbarn.com . Don't be afraid of asking advice and try to ignore ignorant comments .
Old 01-02-2020, 11:35 AM   #13
Stew Masche
Stew Masche's Avatar
A putty knife between the cover and block, tap lightly with a hammer.
Always one bad decision away from a good time.
Stew Masche is offline   Reply With Quote
Old 01-02-2020, 12:04 PM   #14
katy
katy's Avatar
Probably stuck on w/gasket goo of some sort. Leave the 2 large bolts in loosely until it's loose. That way if you shmuck it w/a hammer it won't go flying.
Old 01-02-2020, 12:30 PM   #15
alexiskai
alexiskai's Avatar
That's some good advice there. So I've had two main suggestions: (a) give it some taps with a dead-blow hammer, see if it shakes loose; (b) use a thin implement such as a flathead screwdriver to gently work into the mating surface and see if it can be carefully pried apart.
Thanks all, and to those who DMed, I'll go try this out.
Old 01-02-2020, 02:51 PM   #16
Mad Mac
Leave it alone.
Mad Mac is offline   Reply With Quote
Old 01-02-2020, 04:44 PM   #17
J Franklin
J Franklin's Avatar
Originally Posted by Mad Mac View Post
Leave it alone.
That is good advice often, but the bolts are already out and he has a curiosity.
Old 01-02-2020, 05:51 PM   #18
Jeff/Illinois
Jeff/Illinois's Avatar
Check your Private Messages.
Jeff/Illinois is offline   Reply With Quote
Old 01-02-2020, 09:34 PM   #19
Jack Shaft
Didnt mean to insult anyone.When you mention using a torch to remove the timing gear inspection cover you reveal a bit of your skills.
Old 01-02-2020, 09:49 PM   #20
alexiskai
alexiskai's Avatar
Ha, I do that all the time around here. I've started threads with "I've never done this before" and "Keep in mind I have no idea what I'm doing." I've asked about technical details that turned out to not even exist. I routinely reply to people with "What exactly does that mean?" When someone recommended a dead-blow hammer I had to google what that was (I'm gonna buy one).
People come to FordBarn for different reasons – well, I come here to get educated. I'm not embarrassed about it.
