Old 03-02-2013, 04:43 PM   #1
gwmartin55
Default 38 standard hood
I need to know if any other hood will fit my 38 Standard 5W Coupe? Need to louvre one to see if it helps cooling. Will a 37 hood fit? Any experienced advice appreciated, as they are not easy to find. Thanks in advance
gwmartin55 is offline   Reply With Quote
Old 03-02-2013, 04:51 PM   #2
ford38v8
ford38v8's Avatar
Default Re: 38 standard hood
38 standard hood is an orphan.
Louvers will help, but for a real difference, just leave off the side panels. It looks cool and costs nothing.
Alan
Old 03-02-2013, 06:08 PM   #3
gwmartin55
Can't leave sides off of a standard coupe. All one piece grill.
Old 03-02-2013, 06:24 PM   #4
ford38v8
ford38v8's Avatar
Very interesting. How long have you owned your Chevy now?
Alan
Old 03-02-2013, 07:47 PM   #5
3738
3738's Avatar
Side panels are removeable on my 38 Standard Coupe and on any other 38 Standard Coupe....
3738 is offline   Reply With Quote
Old 03-03-2013, 08:12 PM   #6
gwmartin55
38 5w coupe with the hood not being the deluxe water fall type. Bottom of hood is flat, does not come to a point as a deluxe does.
Old 03-04-2013, 07:00 PM   #7
3738
3738's Avatar
Here's what my 38 Standard Coupe looks like, flat hood as you describe, removeable side panels... (The side panels also come together under the center/front of the hood to form the upper section of the grille)
Old 03-04-2013, 08:50 PM   #8
bart78
bart78's Avatar
Yes a 37 will fit.
bart78 is offline   Reply With Quote
Old 03-04-2013, 09:01 PM   #9
Fe26
Bingo!
Also, if you are overheating it may be a good time to find out why and address the problem/s rather than looking for a secondary fix. Having said that, no side panels is a cool look, especially if you've got some engine goodies or bling installed.
Fe26 is offline   Reply With Quote
