02-19-2019, 05:45 PM | #1 |
Brake Fluid
Have to replace all four wheel brake cylinders on my 40 Sedan, (new when installed years ago).
Because it sat so long the brake fluid Dot#3 absorbed enough moisture to rust the inside. Did a search on search dept... (hunh) to get information about brake fluid use, and found so much difference of opinion on the use of Dot# 3,4,or5, that i still don't know witch way to go. Leaning to go with#5 ? |
02-19-2019, 05:57 PM | #2 |
Re: Brake Fluid
Go with silicone #5. Been using it 30 years. No rust.
02-19-2019, 07:17 PM | #3 |
Re: Brake Fluid
DOT 5 is what I have been using it since 87 when I had to get it at the honda motorcycle shop. I have been told by my counter man that synthetic dot 3/4 is not hydroscopic--???
02-19-2019, 07:54 PM | #4 |
Re: Brake Fluid
Check this thread out-- DOT5/Silicone favored by 52% over all the rest.
https://www.fordbarn.com/forum/showt...ht=brake+fluid
02-19-2019, 08:16 PM | #5 |
Re: Brake Fluid
Thanks everybody for the reply.
02-19-2019, 11:56 PM | #6 |
Re: Brake Fluid
02-20-2019, 12:53 AM | #7 | |
Re: Brake Fluid
Just think of all the twenty year old "beaters" out there that have their original fluid. If there was a significant chance of brake failure because of deteriorated fluid, I'm sure there would be some very strict laws requiring regular periodic maintenance. |
02-21-2019, 09:19 AM | #8 |
Re: Brake Fluid
Tubman, thanks for the "tip" on future buying of DOT 5.
02-21-2019, 10:50 AM | #9 |
Re: Brake Fluid
You really don't save time or work with speed bleeders. You still need a catch can either way. With stock bleeders you just submerge the end in fluid. No need to close screw until finished. Takes one person to pump brakes either way. Waste of $ IMHO.
02-21-2019, 11:05 AM | #10 | |
Re: Brake Fluid
One question : Have you actually ever used "Speed-Bleeders"? I have and much prefer them over the originals. |
02-21-2019, 12:12 PM | #11 |
Re: Brake Fluid
Yes, I bought a pair and was very disappointed in them not saving time. The process is the same except you don't need to submerge the end of the hose. It was an obvious waste of money for me. Never bought the other two.
02-21-2019, 02:09 PM | #12 | ||
Re: Brake Fluid
Stock bleeders can suck air past the threads, Speed bleeders are designed not to. Last edited by 34PKUP; 02-21-2019 at 02:53 PM. |
02-21-2019, 10:23 PM | #13 |
Re: Brake Fluid
Not true. The speed bleeders I bought, have the same pipe thread as the stock screws. They have to or they wouldn't fit into the wheel cylinders properly. You have to loosen them the same as stock ones so they will bleed. The only advantage I saw over the stock ones is you don't have to submerge the other end of the hose in fluid. If that's an advantage at all. Certainly not worth the money. That's why I never bought the other two.
02-21-2019, 10:58 PM | #14 | |
Re: Brake Fluid
The Speed bleeders have a flexible sealer applied to the threads to prevent sucking air back into the system. |
02-21-2019, 11:34 PM | #15 |
Re: Brake Fluid
The two I bought had no special sealer on the threads.
02-22-2019, 12:34 AM | #16 |
Re: Brake Fluid
I surprised this discussion hasn't raised the need to fully flush and clean of the entire brake system and its parts if converting from DOT 3/4 to DOT 5, and also the potential of DOT 5 to find leaks in the system where as DOT 3/4 would not. Or was that just a dream I had ?
The primary reason I install speed bleeders is to eliminate the need to have a second person pump the pedal while I open and close the stock type bleeder. The "hose in the jar" doesn't always work for me .... sometimes it behaved like a snake and had its own mind about twisting around. |
02-22-2019, 05:16 AM | #17 |
Re: Brake Fluid
It is starting to sound like you didn't actually have real "Speed-Bleeders" after all.
02-22-2019, 12:08 PM | #18 |
Re: Brake Fluid
I have dabbled with dot 5 over the years but have settled on using dot 4.
02-22-2019, 12:47 PM | #19 |
Re: Brake Fluid
02-22-2019, 01:00 PM | #20 |
Re: Brake Fluid
Hmmmm. The ones you got must have been defective. The Russel 639590 that just about everybody sells obviously has the "flexible sealer" that "34PKUP" refers to in his post.
