Old 12-04-2021, 12:35 PM   #1
melisahe
melisahe's Avatar
Default 49 ford f1 vacuum
can't find a good place to hook up the windshield wiper vacuum hose. The only place i see is where the distributer vacuum hooks up. Where did the wiper vacuum hook up on the original ford 6 cyl engine? Can I put a "T" in the distributer line? Thanks Mike
melisahe is offline   Reply With Quote
Old 12-04-2021, 03:44 PM   #2
Bob C
Default Re: 49 ford f1 vacuum
Mine has a fitting on the intake manifold just under the carburetor facing the firewall.
Old 12-04-2021, 05:28 PM   #3
FortyNiner
FortyNiner's Avatar
What Bob said.
Old 12-04-2021, 05:52 PM   #4
mercman from oz
mercman from oz's Avatar
Chart - 1949 - 1951 Ford Flathead Six Intake & Exhaust Manifolds - Bob C
Old 12-06-2021, 10:29 AM   #5
melisahe
melisahe's Avatar
Thanks guys, just the info I needed. I don't know why I couldn't see it! Tks again. Mike
Old 12-06-2021, 12:09 PM   #6
rotorwrench
rotorwrench's Avatar
Some used a vacuum booster off of the fuel pump in that time frame They still connected to the usual manifold air pressure fitting but the booster will keep it working when a person has a fair amount of throttle opening. If not the wipers tend to quit when you push down on the accelerator pedal then flap like hell when you let off.
