11-03-2019, 08:40 AM | #1 |
Distributor Part Fits
The point gap specification is 0.018" to 0.022". Considering the radial fits of parts that can affect the point gap, I deduce the following fits (radial clearances) are necessary for a rebuild:
Shaft to Bushings 0.0005" to 0.001" Cam to Shaft 0.0005" Cam Lobe Variation 0.0005" Upper Plate Center Hole to Casting 0.001" to 0.002" The fit that the restorer has control over is the "Shaft to Bushings" because the ID of the bushings is reamed to size. Notice that if all of these clearances become additive, the point gap tolerance becomes zero as the gap would decay to 0.018". What are your thoughts in this scenario?
Bob Bidonde |
11-03-2019, 08:55 AM | #2 |
Re: Distributor Part Fits
Bob, could centrifugal force come in to play at all?
11-03-2019, 08:55 AM | #3 |
I think my head hurts. I just do the best I can, and don't worry about it.
11-03-2019, 09:02 AM | #4 |
Bob -
There are several things under the restorers control that can affect distributor performance. 1. As you indicated, the shaft to bushing tolerance 2. The cam itself - I have seen a lot of cams that are out of spec. The restorer has control over this, as the cam can be replaced. 3. The biggest variable, in my opinion, is the fit of the upper plate in the casting. Worn castings and/or worn upper plates that allow the plate to change rotational center alignment during timing adjustment or due to engine vibration. In many cases where the ears of the upper plate engage in the casting, the castings are badly worn causing the upper plate to slightly change angle as it is rotated. But again, the restorer has control over these items, as distributor castings and upper plates can be replaced |
11-03-2019, 10:24 AM | #5 | |
11-03-2019, 10:39 AM | #6 |
Never thought about tilt. All cylinders need to fire at about or very close to the same place, time and intensity, so any time something shifts it changes that. True the castings can be change, but there are only so many. Most average restorers are only going to have access to maybe one or two to chose from.
11-03-2019, 10:56 AM | #7 |
If you like to learn and futz with things this is great. If you get frustrated or if you just want things to work right Bert's has great rebuilts.
11-03-2019, 11:42 AM | #8 | |
Advice I try to follow. https://en.wikipedia.org/wiki/Rolie_Polie_Olie |
11-03-2019, 11:47 AM | #9 | |
Had to dig that one out of my brain, my kids loved that show. |
11-03-2019, 12:46 PM | #10 | |
As Bob started this discussion about cumulative tolerances that may be out of the restorers control, I just wanted to point out several that we can minimize or eliminate, such as a good cam (Sipes, perhaps) or finding a good distributor core with minimal wear. These cars are so hardy that I also think that we can get ourselves overly concerned with point gap that is off by a few thousands, or timing that is off by a few degrees. We all know that these cars will run with the point rubbing block worn to the point the points barely open, and timing that is slightly off and compensated for with the spark advance lever. |
11-03-2019, 08:55 PM | #11 |
I just replaced my "modern" point set with the original upper plate and point set. Old style points are much easier to set precisely with the screw. HOWEVER, when I wiggled the cam back and forth, I can get as much as 5 thousandths play. Despite that, the car runs quite smoothly.
11-03-2019, 09:11 PM | #12 | |
The spring tension of the points keeps the cam from wobbling while driving. |
11-03-2019, 09:22 PM | #13 |
