Old 08-20-2017, 09:29 PM   #1
VeryTangled
VeryTangled's Avatar
Default Coil Identification
Hi Everyone, I've got these three coils sitting around the garage.
I guess before they find a new home I should figure out what they are for.
One two-bolt with script (first three pictures), and a very similar one without (next three). Seems to me they should be the same application. Then there's the the square-is one which seems to be held on with a wire bail (last three shots).
What have I got?
Thanks in advance for any helpful assistance or comments about rarity, desirability, or not worth the effort!
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
Old 08-20-2017, 09:45 PM   #2
35fordtn
35fordtn's Avatar
Default Re: Coil Identification
Jeff,
The top is a basic 37-41 coil 78-12024 coil
The bottom is a ford 9n tractor coil 9N-12024 for Ford 8N, 2N, 9N tractors with the exception of later production ones with the side mounted distributor.
35fordtn is offline   Reply With Quote
Old 08-20-2017, 10:20 PM   #3
VeryTangled
Wow, That was quick. Michael you're awesome. I know you did that from memory too!
-Jeff H
Last edited by VeryTangled; 08-20-2017 at 10:38 PM. Reason: spelling, always spelling...
